1 members (Hotrod Lincoln), 104 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
#327062 07/06/2007 1:01 PM
Junior Member
Junior Member
Cant seem to get my radio in my 66 Chevy to work. I have power to it and it lights up. I thought it may be the speaker so I hooked it up to another known working speaker and go a very low volume static. Think its a dead radio?
Thansk,
James
James T
www.fixmyprinter.com
But honey...its for us!
#327063 07/06/2007 1:12 PM
Jt,
the fact that you have low volume static is a good thing. I would be suspecting your antenna at this point. Try taking a piece of insulated hookup wire, bare about 1/2" and insert it into the middle hole in the antenna socket.
1951 1 Ton Completed
#327064 07/22/2007 10:10 AM
It could also be the vibrator tube,too;that's what was wrong with the radio in my '55 Ranch Wagon. Cost me about $7.00 to fix back then,probably a $20.00 tube now.
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
#327065 07/22/2007 9:53 PM
James, most likely a dried up filter or bypass capacitor.
60s solid state and semi-solid state radios don't use vibrators to develop the high voltage AC; the transistors were designed to run at the low DC voltage provided right form the car battery; new type tubes were also developed in the late 50s that ran at low plate voltage as well.
James, The radio in your '55 uses a 6 volt 4 pin vibrator; however, if you're going to replace the vibrator you also need to change the buffer capacitor underneath the rectifier socket. Yours uses a .007MFD 1600V cap. Otherwise, the new vibrator will be damaged.
1960 GMC Panel w/ 305 V6, 4 Speed TV Repair Van "The Monitor Lizard"
1961 Chevy Apache 20 283, 4 Speed, Hydrovac
www.picturetrail.com/starchief
#327066 07/27/2007 1:36 PM
Junior Member
Junior Member
Turns out to be a bad antenna cable. Thanks for all the help.
James T
Moderated by  truckernix
