| | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2007 Posts: 31 Junior Member | | Junior Member Joined: Jul 2007 Posts: 31 | Cant seem to get my radio in my 66 Chevy to work. I have power to it and it lights up. I thought it may be the speaker so I hooked it up to another known working speaker and go a very low volume static. Think its a dead radio?
Thansk,
James | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Jt, the fact that you have low volume static is a good thing. I would be suspecting your antenna at this point. Try taking a piece of insulated hookup wire, bare about 1/2" and insert it into the middle hole in the antenna socket. | | | | | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | It could also be the vibrator tube,too;that's what was wrong with the radio in my '55 Ranch Wagon. Cost me about $7.00 to fix back then,probably a $20.00 tube now. Speed | | | | | Joined: Jun 2007 Posts: 90 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 90 | James, most likely a dried up filter or bypass capacitor.
60s solid state and semi-solid state radios don't use vibrators to develop the high voltage AC; the transistors were designed to run at the low DC voltage provided right form the car battery; new type tubes were also developed in the late 50s that ran at low plate voltage as well.
James, The radio in your '55 uses a 6 volt 4 pin vibrator; however, if you're going to replace the vibrator you also need to change the buffer capacitor underneath the rectifier socket. Yours uses a .007MFD 1600V cap. Otherwise, the new vibrator will be damaged. | | | | | Joined: Jul 2007 Posts: 31 Junior Member | | Junior Member Joined: Jul 2007 Posts: 31 | Turns out to be a bad antenna cable. Thanks for all the help. | | |
