1 members (Hotrod Lincoln),
104
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2007 Posts: 30 Apprentice | | Apprentice Joined: Apr 2007 Posts: 30 | I've got a 1951 3100 and it has a large (about 9") round speaker mounted on the center hump of the firewall, below the dash. I have not seen any such animal in the options or accessories but seem to remember seeing something about a "dash speaker" on earlier trucks from the '30s. This sure looks factory installed, nicely snugged-up against the sound batt. Does anybody have any information about this thing?? | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | db'51, I don't think that you will find that installation is an original setup in any way. Is the radio a GM radio or is it a third party make? | | | | | Joined: Apr 2007 Posts: 30 Apprentice | | Apprentice Joined: Apr 2007 Posts: 30 | No radio; just the holes where it once was. The speaker has a cloth covered cable with a round plug with 4 prongs that would have plugged into the radio. Did the original GM radios have any sort of receptacle for a "remote" speaker? Is a "dash" speaker mounted under the dash on the firewall like this one? Thanks for your help! | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | db, the orginal radios did not have a provision for an external speaker. It sounds like you have a module from an older radio.
Fred | | | | | Joined: Jun 2006 Posts: 60 New Guy | | New Guy Joined: Jun 2006 Posts: 60 | db, The in "dash" speaker is located in the dash behind the grill next to the ash tray. Clear as mud, I know. So I've attached a link that shows the speaker location. http://chevy.tocmp.com/chevyresto/51153.htm
Gary, Kelly, and Family
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I will comment on this so that there is no confusion. The speaker for this truck is located inside the radio, it is not separate. The radio is located behind the dash and grill. | | |
