| | | Forums66 Topics128,036 Posts1,055,460 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 327 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 327 | I have my 1954 radio getting repaired when i get it back and i will put it in the dash I know the speaker sits above it but how is it mounted i have a feeling it mounts or screws into the top of the radio or does it screw on to the dash???? Thanks Peter | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I will be watching for the answer to this, too. I have seen photos of the radio with the speaker mounting plate attached to the radio and I have read posts about the speaker being mounted up top in the cab. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | it attachs to the radio and sits right under the grille on the dash
Bill | | | | | Joined: Jul 2006 Posts: 327 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 327 | I suspect it mounts on the radio. I'm going to get a new speaker for this radio And I don't have the mounting plate I thought I could attached it directly onto the radio grill on my dash with out butchering my dash. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | truckernix - the TF series speaker mounts right above the rearview mirror in a special cover, I don't think any of the AD's were like that
Bill | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Bill, would the 54 be like that?
Fred | | | | | Joined: Jul 2006 Posts: 327 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 327 | I think trucker is right I know it mounts some how behid the grill next to the ash tray!! | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The 1954/55 Chevrolet (Advance-Design) truck radio mounts on a plate that is attached to the radio.
The 1954/55 GMC (New Design) truck radio almost looks the same but (among other slight differences) its speaker has a mounting plate that mounts in the roof panel, just to the rear of the windshield.
I am not certain how the speaker wire is attached to the GMC radio. I have a 54/55 radio that has an RCA-type phone plug socket on the top of the radio for a speaker connection. This could be a GMC radio or a converted 1953/54 Chevrolet manual-tune automobile radio.
Do you want to see pictures? | | | | | Joined: May 2004 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 34 | I would love to see pictures of the speaker braket if you have them. I will have to make one for mine. I found the knobs, speaker cover, radio glass,speaker, and radio mounting braket at bowtie bits, hope this help someone, | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | 1954/55 Chevrolet speaker mounting plate. This plate was made out of 1/8" aluminum plate. The original plate was made of 1/16" pressed steel (with side edges turned to provide rigidity). Are the Bow Tie Bits mounting brackets reproduction or used? Did they have the foam/rubber gasket for between the plate and the dash (54/55 rubber/foam is different from 47-43)? | | | | | Joined: May 2004 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 34 | Mounting bracket is (exact repro). Heavy chevy has foam different than 47-53 but no picture on web for 54/55. | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Bill (red58),
I have a 55 2nd (Task Force) and the truck never had a radio or speaker. I have a radio and the speaker box but no speaker yet. Do you know if I can get a thin speaker so I don't have to cut a big hole for the speaker? I ask this because all the trucks I have seen have had a huge hole in the ceiling from the magnet in the speaker.
TIA
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Feb 2005 Posts: 531 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 531 | oldblue, mine is a 56... same thing - no radio. I don't believe the 55.2 and up ever had the speakers in the roof above the rear view mirror.... nor were they in the dash. Quite frankly, I'm not sure where they were. I'm planning on getting the kickpanels with the speakers inside them and augmenting them with additional speakers under/behind the seat. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Larry, the TF trucks did have the speaker above the mirror - sheet 3 shows the hole that needs to be cut for the magnet - I've never seen a speaker thin enuff to fit without the hole, but a good metal worker might be able to add on to the stock cover to make it deeper Bill | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I don't know about a Mono type speaker, but Custom Auto Sound has a stereo speaker that will fit without cutting any holes. I thought that I did see mono speakers for the original type radio, possibly from Harmon's, but I'm not sure of the fitment.
Bill Burmeister | | |
