10 members (55shaker, Hanks custodian, frogfarmer, cmayna, ShopRag, 2-Ton, Mike Roache, Gdads51, mk72, Opelika Tom),
115
Mod | | | Forums66 Topics128,185 Posts1,057,203 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I couldn't stand the suspense any longer, so I went and set up a test with a reducing resistor. I used a 1.35 ohm resistance in series with a 12V supply to a 6V AD radio. I monitored the radio voltage from cold to fully warmed up and it worked perfectly. At cold startup the voltage dips to about 5 V for about 5 sec and then it levels out at about 6.5 V. I can see no problem at all with this approach.
I have read so many negative comments about using a resistor and I really see no reason to fear this method. I would suggest a resistor of about 1.2 ohms and at least a 40 watt rating. | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Did you use the typical ceramic resistors you see at auto parts stores or something special? Do you have a part number and a source? Thanks | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I actually used a combination of high wattage resistors to get that combination. I will look up a part number from a mail order place if that would be helpful. I am thinking of purchasing one of the ones from a truck supplier, to try out. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | there's a resistance unit available from some of the repro places [Filling Station?] called "VOL-TA-DROP" that does the job - about 3" sq ceramic slab w/ a heavy wire wound resistor unit and 2 different current taps, from 5&6amps to 10&20amps - I've got one [10-20] from long ago that I used to run a nice 6V fan in a 12V truck
Bill | | | | | Joined: Feb 2006 Posts: 7 Junior Member | | Junior Member Joined: Feb 2006 Posts: 7 | | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Big Red, what is that in your photo? Is it an aviation related part? | | | | | Joined: Feb 2006 Posts: 7 Junior Member | | Junior Member Joined: Feb 2006 Posts: 7 | It is the " Volt-a- Drop " Red 58 refered to.
Box is marked " Airplane ,Boat, Trailer, Automobile" | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | looks like a vintage model BigRed! mine doesn't mention Columbia, just the VOL-TA-DROP Corp, VanNuys CA, and came in a more 'modern' lookin box same thing tho - not sure if it was the filling station I got mine, they don't have a picture now of the one they offer [#FS-129 $30] - Chevs of the 40's has a high tech one [part# 1119005 $76.25] any other place I've seen has something like an ordinary ceramic resistor or larger coated one that looks wire-wound, and w/ prices around 4-8$, they're not good enuff - wonder if a marine supply might have'em? Bill | | | | | Joined: Feb 2006 Posts: 7 Junior Member | | Junior Member Joined: Feb 2006 Posts: 7 | | | | | | Joined: Jan 2000 Posts: 125 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 125 | The problem with using a resistor is that the radio draws a different amount of current (less I think)until the tube filaments warm up. So to set up a resistor to run the radio at 6 volts normaly results in a higher voltage as it is warming up. This shortens tube life. I may have this back asswards but do know it can be a problem. I had my radio converted to 12 volts by replacing the vibrator, transformer and tubes with 12 volt ones. Not as bad as it sounds as the 12 volt tube radios are plentiful for parts.
Grant 1950 Chevy 3100 1952 GMC 150 (In Pieces) 1968 Chevy K20 1966 Shovelhead 1978 BMW 100S
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Grant, actually that is backwards and the filaments draw more current before they are warm. This results in less voltage across the radio for maybe ten seconds or so. There is actually less strain on the filaments at startup because of this. | | | | | Joined: Jan 2000 Posts: 125 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 125 | Thanks for the correction. I know I was told it was hard on the tubes filaments. Do you know if that is fact or fiction?
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Grant, under normal conditions, 6V filaments with a 6v supply, when the power is applied, there is an immediate surge of current that exceeds the warm operating current. With some tubes you can actually see the light from the heater flare up for a second and then settle down. This is the most stressful moment in the life of a filament. An analogous situation is the incandescent lamp. Light bulbs often "blow" when they are first turned on, because of this affect.
With the 12v supply and suitable resistor, what happens is the initial current surge is much less because of the resistor. The filaments will take slightly longer to warm up, but not by a noticeable amount. This affect is also known as current limiting.
I don't have any scientific data or studies to point to for this application but the analysis is correct and my observations with crude instruments support this explanation. One could hook up a time trace on a scope and record the peak waveform in both cases and I believe the data would tell the story.
As far as the rest of the operating conditions, the resistor solution seems to function quite well.
Fred | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Grant, I have been thinking about my answer for a while and I am going to add to it!
If a 6v radio is run from a 12v supply using a correctly chosen resistor value, the radio will perform normally. If then one of the filaments burns out, the radio will stop working, which is normal. What will happen though is that the voltage to the radio will go up some because less current is passing through the resistor. If the radio was continually left on, it is conceivable that another filament could blow and of course the voltage would go up again. Ultimately, leaving a nonfunctioning radio turned on while powered through a dropping resistor could eventually result in a radio being fed with a voltage close to 12v.
This whole scenario could be avoided by using a solid state regulated supply which delivers the same voltage constantly. | | |
