| | | Forums66 Topics128,024 Posts1,055,390 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Can anyone recommend someone to recone a dash speaker. brian | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | you can prolly get a new one from the repro dealers, but if ya can't, this place might help Bill | | | | | Joined: Oct 2005 Posts: 738 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 738 | I would go for a new one, unless it is an origionality thing.
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton My Machine | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | thanks all, I have never seen a new one listed for 60-66, I will send mine to speakershop & try them out,,brian | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Brian - are none of the ones at the bottom here appropriate? Bill | | | | | Joined: Apr 2005 Posts: 313 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 313 | I was put a 6" x 9" speaker from Radio Shack in my '66, and it fit right in. It cost me about $10.00 at the time.
Reconing your old speaker will probably run you about $35.00 or so. | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Bill, I got the 1964 OE AM jam working, but the speaker is rough. Its kinda odd how it fits up into the dash, has funny mounting apparatus. I have been told(here) that impedance needs to be close or it will overheat the radio, not sure if aftermarket would work alright or not. the last time I went to Radio Shack they told me they no longer carry car audio at all. brian | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | all the single original style speakers available for vehicle radios are all close enuff to right there won't be any problems - they're about 8 ohms, but 4-12 will work, just hafta find one that fits just figger if the replacement speaker could be fit into your original mounting setup - the 67 radio I've got just has a usual style speaker that's fit to a bracket on the radio that holds it in the right position to be against the metal grillwork in the dash surface - doesn't show the speaker well, but like this Bill | | |
