8 members (MickeyP, dt235sd, Donf, Peggy M, Brian Moore, R-galla6, 55shaker, 1 invisible),
156
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,279 Posts1,058,583 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2004 Posts: 39 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2004 Posts: 39 | anyone know the size of the radio that goes in 47-53 chevy trucks? the size of the housing is what I'm looking into, not the knobs or dial face etc. just the general dimensions. thanks. | | | | | Joined: Mar 2002 Posts: 9,117 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,117 | I should be able to send you something in the next few days. The unique thing about the AD radio is the angle of the controls relative to the case. It is different than most of the other GM radios of the time period. | | | | | Joined: Mar 2002 Posts: 9,117 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,117 | powerband, I have Emailed you the dimensions of the 1947 to 1950 AD truck radio. You will notice that they are added to the diagram from the manual. This will give you an idea of the shape and angles involved. | | |
