4 members (klhansen, N-man, 3800GUY, Hanks custodian), 69 guests, and 2 robots.
Topics128,131
Posts1,056,726
Members48,454
I am building a trailer from an old bed. I was planning on running a fiberglass resin coated sheet of plywood in it as a floor. But I got to thinking, is there anything like that plastic stuff that they make decks and fences out of these days in a sheet?
Brian
1948 Chevy Pickup
Chopped and sectioned
owned since 1974 when I was 15.
look for stuff called "arena board" to put on top of marine plywood - it's the plastic sheet they use around hockey rinks [where it might be called 'puck board'], near bullet proof
You can buy 4x8 sheets of plastic like they use in car washes right at Menards.
More durable hum bug. My 41 has the orginal wood bed and was used to haul grain and how knows what for the 20 years it was a farm truck. Just a little sand paper and a new coat of varnish and its as good as new. Accept the few deeper gouges but hey they are beauty marks smile
Four inches of concrete with rebar in it oughta be just about bulletproof.
1948 Chevy 1/2-Ton
"Tuesdays with Morris"
In the Legacy Gallery
Find it - Fix it - Drive it
I used a composite deck product called Veranda...available from Home Depot. Its a grey color, comes in 8' lengths, cuts like butter and has a wood-grain print on one side. I followed their directions as far as spacing and used carriage bolts instead of the bed strips. I didn't add any additional bed cross members and after a year it looks as good as the day I installed it. I have a picture in my webshots "Shoebox album" (pg 8). Hope this helps.
Dave
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
I would steer away from any coating over wood even marine treated. My father-in-law was in the boat business and I've seen high dollar Sea Rays just a few years old with rotted decks. They use a marine plywood and it just won't hold up like good old oak or hickory or some other hardwood. Fiberglass over wood holds in the moisture. You want the wood to breath and dry out.
Just my 2 cents...
~Jim
Some great stuff, THANKS!
I'll post when I am done. I just picked up that axle and hubs today, can't wait to get it on the road again!
Brian
1948 Chevy Pickup
Jim & Caroline
aluminum checkerplate?
GMC: Get More Cash...
1958 GMC
My Webshots photos
