1 members (Truckrolet), 156 guests, and 1 robot.
Topics128,115
Posts1,056,291
Members48,439
#325649 02/07/2007 3:41 PM
Anonymous
Unregistered
Anonymous
Unregistered
Just completed installing my locking fuel door into the bed wood for my 54. I can now finish the staining and apply the urethane.
Here is the fuel door;
http://www.picturetrail.com/gallery/view?p=999&gid=8309838&uid=2902753
Houston, where did u get the fuel door? Need one for mine.
Anonymous
Unregistered
Anonymous
Unregistered
Found it on ebay of course. I recall the seller saying it was used on a dodge durango. I have seen them in som epickup accessory stores and a quick yahoo search found this link.
http://www.autoanything.com/chrome-accessories/61A1996A0A0.aspx
Thanks Houston
nice looking fuel filler!
1950 Chevy 3100 5 window "in progress"
1967 Chevelle 300
V
V Offline
Houston54
Just looked at the nice job you did on your fuel door. I was curious when I looked at photo #10 what gas tank set up you used?
I like what you did with this truck its real classy looking.
Anonymous
Unregistered
Anonymous
Unregistered
Vick,
The tank is a 1st Gen camaro/firebird 18 gallon tank. It is supported with custom bent straps I made. It is pretty wide but it fits. The exhaust pipes took some fancy bending to get over the axle and around the sides of the tank but it works well. The fuel bung was cut from the original and installed using some 2 inch rubber hose and clamps. The anti-squeak strips were cut from some tar paper from a local building site. Glad you like our efforts. We are happy with the way it is turning out also.
#325656 04/02/2007 11:26 PM
V
V Offline
Thanks Houston 54.
I'll probably be doing the fuel tank and door thing sometime in the fall. Sure am glad you shared these wonderful photo's and explantations.
Vic
