1 members (Southerntruck),
73
Mod | | | Forums66 Topics128,049 Posts1,055,635 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I got the wood refinished (pre crash). I used spar varnish after dicussing it with a cousin whos husband does home and wood restoration. I used 7 coats with 3 coats of red oak stain under to take care of the grey spots. http://rides.webshots.com/photo/2500048230092261295nCptxt
Bill Burmeister | | | | | Joined: Mar 2005 Posts: 311 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 311 |
Always get a 2nd opinion, especially if I am the source of the 1st opinion.
| | | | | Joined: Oct 2001 Posts: 428 Shop Shark | | Shop Shark Joined: Oct 2001 Posts: 428 | | | | | | Joined: Jan 2002 Posts: 866 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 866 | Nice!! You did a great job on the wood. | | | | | Joined: Jun 2003 Posts: 565 'Bolter | | 'Bolter Joined: Jun 2003 Posts: 565 | That looks really good. Did you seal all sides to prevent moisture getting in through the bottom?
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The bottom had been done with Pelucid fro POR 15, as had the top. The top reacted badly to the UV and started to peel. The bottom was very sound, so I only did the tops and overlapped it on the sides. I beleive the bottoms will be OK as there isn't any UV hitting them. I also have a rubber floor mat that I'll use to cover the wood when the UV is really bad in the summer.
