8 members (Rusty Rod, TUTS 59, Peggy M, 3B, J Lucas, David Bush, Southerntruck, 1 invisible),
103
Mod | | | Forums66 Topics128,065 Posts1,055,863 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2006 Posts: 236 'Bolter | | 'Bolter Joined: Apr 2006 Posts: 236 | I think this question has been asked before, but I couldn't find the answer. What direction do the eccentric washers face? Is it with the large end towards the cab? Also, any advice on making the recessed areas so the washers will be flush with the bed wood?
58 Fleetside, 235, "The Old Buckin' Bronco"
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Lumbergh,
Don't know about the washers, but a Forstner bit works great for the recessed holes...clean edge, no tear out.
Stuart | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Large end to the front. I know that the procedure is in here some where for soing the recesses, but I don't recall when it was posted. Are you making you're own boards? I had the holes done for mine when I ordered them from Mar-K. The cost was minimal compared to the work doing them myself.
Bill Burmeister | | | | | Joined: Apr 2006 Posts: 236 'Bolter | | 'Bolter Joined: Apr 2006 Posts: 236 | Thanks for the info. I ordered the boards without the predrilled holes just to be safe. This way, I knew that the holes would match up to the bracing, since I would be marking them and drilling them based on the exact position of the bracing in my truck bed. If I ordered the boards predrilled and any holes didn't match up, that board would be useless, as you can't undrill a hole. Look forward to any other recommendations, as I plan to start this Saturday.
