| | | Forums66 Topics128,113 Posts1,056,279 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 23 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 23 | I got my cross sills without the holes pre-drilled and want to know where the holes are supposed to be? Does anyone have measurements for where the holes should go? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | careful about using someone elses measurements! it would depend on the width of the boards, and where the holes in the skid strips are, which is why they make sills without holes - if you don't have holes in the skid strips, you need to lay it all out yourself, if the skids have holes, lay up the whole floor and mark the sills thru the skids
Bill | | | | | Joined: Dec 2005 Posts: 406 Shop Shark | | Shop Shark Joined: Dec 2005 Posts: 406 | Spencer: The holes will be along the center of the cross sill and aligned with the holes in the rear sill. If this is for your 49, there are 8 bed strip holes for 1/4" bolts and two angle strip holes for 5/16" bolts. Matching them to the holes in the rear sill is a very accurate way to get them right and then everything will line up. Drill about 1/2" holes for the bed-to-frame bolts spaced to match the frame mounting holes. Front cross sill has extra holes on its forward face to bolt it to the front bed panel, aligned with holes in the flange of the front bed panel.
I am curious, why did you buy them without holes?
Mar-Ktech | | |
