3 members (ronsway, ndkid275, klhansen), 89 guests, and 3 robots.
Topics128,090
Posts1,056,374
Members48,442
Junior Member
Junior Member
Hi all, (new guy here... )
I have purchased a '55 side mounted spare bracket for my '52 Chevy pickup. It wasn't intentional, the eBay auction said '47-'53 but it's made for a flat top box. I have also eBayed a "side mounted spare" fender (with the indent).
Does someone on here have an Advance Design '47-'53 1/2 ton truck with the side mounted spare option? If so, could you measure the horizontal and vertical hole locations to mount the bracket to the box side?
I could do the "trial and error" thing but would prefer dimensions. The Assembly Manual I have only shows a '54 (flat top) box and it's not clear what the dimensions are from the front of the box (Sect 10. sheet 3.01 for those of you that have the manual).
This is a great site, I've been surfing it awaiting approval of my registration and I'm going to love coming here.
Thank you all, any help would be greatly appreciated.
52 Chebby
ill go measure mine its a 52 bed with spare indent not in very good shape but i sould be able to get a measurement from some where on it.ok if you butt your tape against the stake pocket at the front bed panel the bolt hole will be 1"to center and 11 3/4 to center of next hole.now hook tape on the bottom of bed side and pull up 3 1/4 to center of hole and 16 3/4 to next hole. hope this helped.
john
