8 members (78buckshot, Thom75, Mike B, Lightholder's Dad, UtahYork, cmayna, tclederman, 1 invisible),
186
Mod | | | Forums66 Topics128,271 Posts1,058,416 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 144 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 144 | I'm presently rebuilding and restoring the bed on my 46. After I got it all apart I found that the two middle crossmembers were bowed or arched down a bit and was wondering if this is normal for the Art Deco series or is it from carrying loads over the years and has anyone seen this before. I imagine they should be straightened out or the boards won't line up properly and when bolted in there would be a depression in the middle of the box. I'm thinking of using a hydraulic press to straighten them if they need to be. Any info would be appreciated. Bob T | | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | Bobt: what's left of mine on a '41 3/4 ton are straight. | | | | | Joined: Mar 2005 Posts: 144 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 144 | Thanks kip's 41, looks like I'll have to straighten them as the bed would probably show a large depression when installed, not good. Farmers around here either carry large fuel tanks or water tanks on there truck beds and over time I imagine bows the crossmembers. Probably a litlle bit of heat in a hydraulic press will straighten them out. thanks again. Bobt | | |
