Brrrr
place holder
6 members (Maybellene, Shade Baby, Sjm, SNOYL, Guitplayer, 1 invisible), 104 guests, and 2 robots.
Topics128,271
Posts1,058,417
Members48,485
#325458 10/19/2006 1:58 PM
I'm presently rebuilding and restoring the bed on my 46. After I got it all apart I found that the two middle crossmembers were bowed or arched down a bit and was wondering if this is normal for the Art Deco series or is it from carrying loads over the years and has anyone seen this before. I imagine they should be straightened out or the boards won't line up properly and when bolted in there would be a depression in the middle of the box. I'm thinking of using a hydraulic press to straighten them if they need to be. Any info would be appreciated. Bob T
Bobt: what's left of mine on a '41 3/4 ton are straight.
1941 Chevy Master 3/4-Ton
More images in the Bolt Bucket
Born to fish, the truck is only a hobby.
Thanks kip's 41, looks like I'll have to straighten them as the bed would probably show a large depression when installed, not good. Farmers around here either carry large fuel tanks or water tanks on there truck beds and over time I imagine bows the crossmembers. Probably a litlle bit of heat in a hydraulic press will straighten them out. thanks again. Bobt
