2 members (59 fleet, KEVINSKI), 157 guests, and 2 robots.
Topics128,034
Posts1,055,551
#325454 10/16/2006 10:51 PM
Am I doing the bad all backwards, or something? I had the sides, tailgate, front, all together and painted. It's been on sawhorses while I put in the wood. I used wood strips to determine how far apart the mounting holes would be and marked the wood accordingly. When we placed the assembly on the truck's frame today, none of the holes line up! Luckily, all I had done to the bed wood was drill the 1/8" pilot holes, so if I have to move them, it won't be too bad.
Now, you should know that I installed new cross members, and I laid the old ones on top to determine the hole placements. I know a few (many) are not where they should be, and I'll have to make adjustments (bigger holes....)
My question is, should I loosen the bed wood (only the center five are in) and take them off the frame, set the bed sides assembly on the truck frame and try to align it peoperly with the frame before reinstalling the wood? Will this work, or is there a better (or easier) way to do this?
I'm getting really discouraged. It seems that nearly every new part I purchase for this truck isn't quite the right size, or some adjustment has to be done to get stuff to fit.
The bed wood, for example, is too wide for the truck. When I installed it, there was an inch and a half too little space for the final board, so I had to shave the outside boards by 3/4" each to make everything fit. (Sorry I didn't get Mar-K wood back 12 years ago when I bought this stuff.) This is making the mounting holes interfere with the bed strips, but I think I can work around it when I get things straightened out.
Is there any wisdom from 'bolters who have run into similar problems.....?
1948 Chevy 1/2-Ton
"Tuesdays with Morris"
In the Legacy Gallery
Find it - Fix it - Drive it
I have only done 3, & they were all fleetsides, but I installed all boards loosely(bedsides & front all painted & assembled), once the boards & strips were installed I took measurements from corner to corner to square it up. Tightened all the bolts once squared. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
I finally got it all straightened out and the bed is now finished. I had to mount the bed assembly with the frame bolts, then work in the wood while everything was on the frame. It was a real struggle to get everything lined up properly and bolted in, especially since my '48 has the gas tank under the bed, but it all worked out.
1948 Chevy 1/2-Ton
[QUOTE]Originally posted by Tom R:
[QB]
I got a chuckle out of the boating quip, I will probably steal it sometime,(not on the bolt)
