2 members (mick53, klhansen), 118 guests, and 0 robots.
Topics128,113
Posts1,056,277
Members48,439
1950 shortbed. 9 board bed. anyone got some advice?
im looking for a link to a website that offers the dimensions of the grooves that need to be cut for the metal strips. also, i cant find yellow pine in my area, anyone use normal white pine instead? does it hold up pretty well?
im also curious about the dimensions of the wooden blocks that go between the bed and the frame. anyone feel free too chime in at any time, any adivce would be appreciated
Quote
White pine is usually a lot softer than yellow pine, which is why yellow pine was originally used on these trucks. How well it holds up will depend mostly on the finish used and on how much the bed is used like a truck.
We recommend making the wood blocks 2-1/8" tall since the cross sills are 1-7/8" tall. This makes the bottom of the bedwood 4" above the frame. The brackets on the rear sill are 4" tall and it all has to match.
Use the spacing of your bed strip holes in a cross sill or rear sill to calculate the width dimensions for the bedwood. If you use our formulas in the link above and measurements taken on your truck, the wood will fit.
Jeff Nelson
"Beer is proof that God loves us and wants us to be happy." - Benjamin Franklin
"Always do right. This will gratify some people and astonish the rest." - Mark Twain
great advice guys thanks alot
Heck, I went so far as go to the sawmill for mine. had to wait a year for them to dry, then runthru a plane.
