7 members (Oswald, FAST55, Ponchogl, 2-Ton, Oldcaliforniakid, Hotrod Lincoln, Donf),
74
Mod | | | Forums66 Topics128,042 Posts1,055,519 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2001 Posts: 279 Shop Shark | | Shop Shark Joined: Mar 2001 Posts: 279 | Any tips on cutting the bed wood for off-set washers? My bed wood came from Jim Carter, but it wasn't drilled for the washers. I thought about a Forstner bit, but am concerned about it screwing up the appearance. What is the best thing to use and any tips to keep it from looking like crap from slippage when done? | | | | | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | Rick - That's what I used on my bed. You'll need to use in in a drill press though. I wouldn't try to drill those recesses by hand. Check out the Mar-K site I think they have some instructions on how to get them offset properly. Good Luck George | | | | | Joined: Dec 2005 Posts: 406 Shop Shark | | Shop Shark Joined: Dec 2005 Posts: 406 | Originally posted by 46forme: Check out the Mar-K site I think they have some instructions on how to get them offset properly. Good Luck George Rick: That instruction is on our site http://www.mar-k.com/drilling_mounting_holes.html . Be careful to control the depth carefully and by all means use a drill press if you have one available. By drilling the 1 9/16 recess before drilling the 1/2" hole for the bolt, your forstner bit point will guide the cut and avoid splintering or walking around. Use some scrap material to get your settings right before drilling into the bed wood boards. Mar-Ktech | | | | | Joined: Mar 2001 Posts: 279 Shop Shark | | Shop Shark Joined: Mar 2001 Posts: 279 | Thanks for the tips. I had already drilled my bed-to-frame holes when I installed the bedwood last year. I mounted them with the off-set washers above wood level. So I'll have to drill with those holes already drilled through. I have a hand drill press that might do the trick. It also has a depth stop on it, so hopefully it will work. I'm not ready to do this yet, but will do it in a month or so. Thanks again for the tips. | | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | Try using a router after marking offset if installed washers already. On removed boards get a good grip on preset router and go for it. Nice and slow.
Dan | | | | | Joined: Mar 2006 Posts: 483 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 483 | I used a holesaw without the center drill bit on my drill press to do my off set washers then drilled the center 1/2" holes | | | | | Joined: Sep 2005 Posts: 20 Apprentice | | Apprentice Joined: Sep 2005 Posts: 20 | This might help. Plug the bed frame holes back up with a dowel. Make sure its in there pretty tight. Saw of flush (even) with the original surface. Then start again with the larger hole. If you know any cabinetmakers they might let you borrow their plug saw. | | | | | Joined: Jun 2006 Posts: 24 New Guy | | New Guy Joined: Jun 2006 Posts: 24 | How about using a forstner bit on a scrap piece of wood, say a 1x6, center the hole end to end and leave the board long, about 24 inches. Position the hole you just drilled on your truck floor where you want it. With both knees on the scrap board drill between your legs. Use the hole you drilled to guide your bit, work slow. The pressure from the scrap should keep the wood from underneath from splintering. Gauge your depth by eye. I used this when making a tool rack. I drilled the holes for screwdrivers, when I wanted it for handles to sit in a recess.
1957 3805 Panel It's not how you fall down, but how you get back up.
