Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (Otto Skorzeny, UtahYork, Hotrod Lincoln, frogfarmer), 162 guests, and 3 robots.
Topics128,284
Posts1,058,525
Members48,490
#325070 01/17/2006 6:20 AM
Junior Member
Junior Member
Anyone have the dimensions, or guide for cutting the wood in a 1953 3100 short bed pickup. Don't won't to buy prefab kit. I have friend that has woodshop, and can fabricate the wood for me cheaply. Just need dimension, width, length, thickness, groove depths... I do not have any of the old bed to go by, so I have no templates
1958 Chevy 1/2 ton Apache Stepside Longbed
Never trust a driver with a collision shop courtesy car
Photo Album
Junior Member
Junior Member
Thanks magmolia that will help
I am curious, has anyone on the board actually cut and used this recommended pattern? How did the wood fit? Would someone that has personal experience with this pattern verify the fit? If it didn't fit quite right how would you change it to be better?
We use a different groove dimension http://www.mar-k.com/bedwood_dimensions.pdf and slightly different measurement on board width.
People often want to cut their own bed wood for various reasons and reliable dimensions are critical. All information and help here is appreciated, especially when the information comes from personal experience.
Mar-Ktech
It looks like there may be a problem with the link to my bedwood dimensions pdf. I will ask our webmaster to repair it soon and post again.
Mar-Ktech
I used the late 51-53 width info, board lengths, and groove info on my 53 shortbox. Each board was about, I would say, 1/8 of an inch to wide when I fit it all in the bed because I ended up shaving an 1/8 of an inch off one side of each board. Then redrilling about half of the holes in the rear sill. The boards are tight against the bolts on either side still. That's my first time experience. If I did it again, I would fit all the boards before I cut the grooves. If you do cut yours smaller and then it is too small, please don't blame me. Best of luck.
Colin
Colin:
Thanks for responding. It appears these dimensions given may not be correct and should be modified before just cutting the boards. Your suggestion of test fitting all boards before cutting the grooves would eliminate a lot of extra work to fix problems after the fact.
We cut bedwood according to this drawing, http://www.mar-k.com/bedwood_dimensions.pdf and have sold thousands of sets of bedwood. It requires that you actually measure the spacing of bed strips and cut the wood to fit. I recommend anyone cutting their own wood to make these basic measurements and develop their own wood dimensions for their own truck. Even then, some scrap pieces should be cut to the width dimension to test the fit in the truck. The width hard to get correct but it is critical. Let me know if you have questions about how to use the drawing.
Mar-Ktech
