| | | Forums66 Topics128,284 Posts1,058,523 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2006 Posts: 4 Junior Member | | Junior Member Joined: Jan 2006 Posts: 4 | Anyone have the dimensions, or guide for cutting the wood in a 1953 3100 short bed pickup. Don't won't to buy prefab kit. I have friend that has woodshop, and can fabricate the wood for me cheaply. Just need dimension, width, length, thickness, groove depths... I do not have any of the old bed to go by, so I have no templates | | | | | Joined: Aug 2005 Posts: 183 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 183 | | | | | | Joined: Jan 2006 Posts: 4 Junior Member | | Junior Member Joined: Jan 2006 Posts: 4 | Thanks magmolia that will help | | | | | Joined: Dec 2005 Posts: 406 Shop Shark | | Shop Shark Joined: Dec 2005 Posts: 406 | I am curious, has anyone on the board actually cut and used this recommended pattern? How did the wood fit? Would someone that has personal experience with this pattern verify the fit? If it didn't fit quite right how would you change it to be better? We use a different groove dimension http://www.mar-k.com/bedwood_dimensions.pdf and slightly different measurement on board width. People often want to cut their own bed wood for various reasons and reliable dimensions are critical. All information and help here is appreciated, especially when the information comes from personal experience. Mar-Ktech | | | | | Joined: Dec 2005 Posts: 406 Shop Shark | | Shop Shark Joined: Dec 2005 Posts: 406 | It looks like there may be a problem with the link to my bedwood dimensions pdf. I will ask our webmaster to repair it soon and post again.
Mar-Ktech | | | | | Joined: Apr 2001 Posts: 439 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 439 | I used the late 51-53 width info, board lengths, and groove info on my 53 shortbox. Each board was about, I would say, 1/8 of an inch to wide when I fit it all in the bed because I ended up shaving an 1/8 of an inch off one side of each board. Then redrilling about half of the holes in the rear sill. The boards are tight against the bolts on either side still. That's my first time experience. If I did it again, I would fit all the boards before I cut the grooves. If you do cut yours smaller and then it is too small, please don't blame me. Best of luck. Colin | | | | | Joined: Dec 2005 Posts: 406 Shop Shark | | Shop Shark Joined: Dec 2005 Posts: 406 | Colin: Thanks for responding. It appears these dimensions given may not be correct and should be modified before just cutting the boards. Your suggestion of test fitting all boards before cutting the grooves would eliminate a lot of extra work to fix problems after the fact. We cut bedwood according to this drawing, http://www.mar-k.com/bedwood_dimensions.pdf and have sold thousands of sets of bedwood. It requires that you actually measure the spacing of bed strips and cut the wood to fit. I recommend anyone cutting their own wood to make these basic measurements and develop their own wood dimensions for their own truck. Even then, some scrap pieces should be cut to the width dimension to test the fit in the truck. The width hard to get correct but it is critical. Let me know if you have questions about how to use the drawing. Mar-Ktech | | |
