Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
2 members (MickeyP, KingG), 60 guests, and 0 robots.
Topics128,007
Posts1,055,281
Members48,418
#32140 03/20/2003 6:10 AM
Oly
Offline
Gonna be building the Sleeper55's engine in the near future. It's a 55 235 with Tattersfield dual intake. I have lots of Rochester carbs and one Carter, but I could get another Carter if need be. the question is- which carbs should I use? Is one type carb better for this application and why. This engine will be mildly enhanced.
Oly in Oregon
Rest in Peace
1945 GMC COE Victory Truck
1953 Willys CJ3B
1955 Chevy 1st series 3/4-ton
1958 WIFE Last series
Never say "Whoa" in a mud hole
#32141 03/20/2003 6:36 AM
Coming from Oly,,,,The old engine rebuilding guru???
What linkage are you using?
WHat carbs will fit on the manifold?
#32142 03/20/2003 8:20 AM
The old speed books promote the use of Zenith carbs , , but Stromberg carbs are better and will probably cost you more.
Keep checking e-bay.
#32143 03/20/2003 5:38 PM
Oly
Offline
Dusty, do you have any numbers that I might, should, look for?
Oly in Oregon
Rest in Peace
1953 Willys CJ3B
#32144 03/20/2003 11:01 PM
This looks like a Chevy carb.
Zenith carb
'38 Chevy 1-1/2 ton
'49 Chevy 1/2 ton
'54 Chevy 6400 2 ton
'55.2 GMC 3/4 ton
'56 GMC 1-ton
No Room Left in Shop
#32145 03/20/2003 11:34 PM
The carter and zenith carbs are easier to tune for multiple installations than the Rochesters. I'm going to use two 2bbl Holley 94's with an edmunds intake on mine. You can buy adjustable main jets and differant vacuum power valves for them.
Paint & Body Shop moderator
#32146 03/21/2003 1:12 AM
olBlue found'em for ya, Oly - check the mount hole spacing to be sure and fly at it - there's a pair of'em and they look "new" - maybe 40 bucks for the pair?
#32147 03/21/2003 3:06 AM
Oly
Offline
Thanks olblue, looks like maybe they will work out. I seem to get lost on Ebay. I never know what to look for-LOL.
Oly in Oregon
Rest in Peace
1953 Willys CJ3B
#32148 03/21/2003 4:43 AM
Geez, if I could just find some of the stuff I need that easy....
'38 Chevy 1-1/2 ton
'49 Chevy 1/2 ton
'55.2 GMC 3/4 ton
'56 GMC 1-ton
#32149 03/21/2003 5:21 AM
why are the zenith carbs better than the rochesters?
#32150 03/21/2003 11:26 PM
Carburetion specialist
Check the manifold bolt pattern. Size 2 carburetor bases have center-to-center spacing of two and eleven/sixteenth inches. Size 3 carburetor bases have center-to-center spacing of two and fifteen/sixteenth inches.
We really like the Carter W-1 (1946-1948 Chevrolet) for size 2 carburetors (mechanical power system).
For size 3 carburetors, Zenith 28AV12, 28BV12; Stromberg BXOV-3, and BXUV-3 work well.
In any case, an EXACT MATCH BY PART NUMBER is desirable.
Jon.
The Carburetor Shop
