Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
3 members (GMCJammer51, Bill Hanlon, 3B), 58 guests, and 2 robots.
Topics128,009
Posts1,055,296
Members48,419
#32068 09/29/2002 4:20 AM
Today I finally got around to doing something with the '42. I got the 216 pulled and the bell housing removed to install on the 235 I have sitting in the corner. I looked real hard at installing the 261 I recently overhauled, but the 261 is not quite done and I don't have the extra cash sitting around to finish it right.
The 235 has been overhauled and ran good when a buddy of mime parted out his farm truck. If tomorrow is as nice as today, I should get the 235 sitting in it's new home tomorrow afternoon.
What really surprised me about the 216 is that the starter worked at all. In the 15 years the '42 set in a tree claim, the mouse nests in the flywheel area gathered enough moisture to rust some of the teeth off the starter ring gear. The clutch surface on the flywheel was deeply pitted. I guess that explained the 'chunk' noise I hear while cranking the engine over.
It will be nice to have a 235 under the hood, although the 261 (bored .030) would have been better had finances allowed.
Remember 9-11-01--God Bless the USA
JUSTICE, not REVENGE, will prevail
1951 Chevy 1/2-ton Pickup truck
#32069 09/30/2002 3:53 AM
What a beautiful day!!!! I got the 235 set in the '42 with a few minor but not insurmountable problems. I just hooked it up to the OEM crashbox tranny because I don't have time or $$$ to switch over to the synchronized M-420 I have sitting around.
It was a nice benefit to listen to the B-24 flying overhead while I was working.
#32070 10/04/2002 7:18 PM
Hows the 42 comeing along?sure would like to see some pics.Im also curious as to any modificatioins you have to make.They are such a neat looking truck.Is that a pre or post war 42?
1942 1\2 Ton
1951 1\2 Ton 55 willys cj-5
1954 and 59 Cushman Scooter
1960 Biscayne Sedan
1965 G/10 panel van
1966 C/30 Grizzly Motorhome
You know you're a 'Bolter when your daily driver is older than you are...
My progress pics
#32071 10/05/2002 3:02 AM
It is a pre-war '42 (I think??) The grill has no chrome on it.
I will have to lower the stock radiator as the fan blades hit the lower radiator neck. There is enough metal on the radiator to do this--I just have to drill some new holes.
The throttle linkage will have to be shortened about 2".
This engine came with solenoid starter. I remember reading something about the bendix and starter teeth being different between the stock six and 12 volt starters and sure enough the 12 volt starter is a little smaller all around. This means I can't use my foot starter anymore, but I'll survive. In the lower left corner of the dash is a button labeled 'start'. I have always been a little curious about that button--it that stock?? I will use this location for my new starter switch.
I hope to get back to the truck this weekend and get it finished--I am almost finished with a tractor I overhauled and need the truck to transport the tractor back to it's home. I'll try to remember the camera this weekend. The truck looks a little funny with the front clip removed and laying in pieces on the bed.
#32072 10/05/2002 6:57 AM
Im geussing that the button is not stock.At least idont have one on my 42.Just the key and the foot switch.Idid the 235 switch in my 51.Iused the 216 fly wheel and bell houseing to keep the stock starter.Mainly so i wouldnt have to spend any more money.I see you intend to use the truck for towing.Im curious as to your thoughts on the 235s towing capabuiltys.Iam mainly interested in towing a pop up camper with my truck.The most interesting art deco ive seen is my neighbors.He use,s it as a wrecker.He has a 4 wheel drive front axle on the rear hooked up to a ram so that he has 4 wheel steering.Definetly different.
1942 1\2 Ton
1960 Biscayne Sedan
1965 G/10 panel van
My progress pics
#32073 10/07/2002 4:11 AM
Well, today I got the 235 running in the '42 and even drove it a little ways without the front clip on just to make sure everything was right before I put the clip back on again. WOW! What a difference!! The 216 had enough of a load with just the truck by itself getting up to speed, but this 235 really seems to have a lot of power. I may be able to get up to 50 mph on the highway now instead of 35 before. I did notice the RH rear wheel is leaking AGAIN :mad: :mad: :mad: . They say there is no speedy sleeve made for this size seal, so I will have to figure something out.
With all this additional power, I had better have good brakes!!!!
Sorry Ron, I was over at the shop and had been working for about an hour before I realized I forgot the digital camera. Just picture a truck with no grill and fenders running down the road. grin
