2 members (GMCJammer51, TUTS 59), 88 guests, and 2 robots.
Topics128,186
Posts1,057,324
Members48,469
Junior Member
Junior Member
I have a 57 NAPCO panel with the original 4 speed tranny. There is an intermediate shaft between the tranny and the transfer case. So I'm looking for a 5 or 6 speed, 2WD tranny that will handle 6000 lbs. 3.91 gears, I'd be happy to have a bellhousing made. All the trannys I find don't look heavy enough to handle the load. Any suggestions?
Anonymous
Unregistered
Anonymous
Unregistered
Clark 5 speed from the same era? Most versions had fifth gear direct, but there was a version in which fifth was overdrive. They are pretty big though(used in the bigger trucks of that period) and getting hard to find.
I
I Offline
Here's an ongoing thread on another board that may help. They list the Clark 5-speed model number that has OD. 280VO with .83 OD.
http://oldgmctrucks.infopop.cc/eve/ubb.x?a=tpc&s=272004236&f=633004236&m=8601001501
NV 4500 or NV 5600? Both are modern 5/6 speed manuals. Both should easily hold up to any motor of that era; they are used behind the cummins. Easy to adapt to 350-style bellhousing pattern. NV4500 rated at 19500# GVW, with .73 OD. NV 5600 rated at 26000# GVW, .73 OD. Just a thought.
"If the women don't find ya handsome, they should at least find ya handy!"
1961 Apache 20 4x4
http://community.webshots.com/album/97352016vHsKNP
