| | | Forums66 Topics128,139 Posts1,056,459 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#31963 06/05/2003 2:44 AM | Joined: Jan 2003 Posts: 26 Member | | Member Joined: Jan 2003 Posts: 26 | This has probably been commented on too many times, I've just missed it. My steering wheel is pointing a 2 o'clocki instead of noon when I'm goin straight down the road. Is this a tie rod adjustment or pulling the wheel and making the adjustment? If it's the wheel, con you walk me through it? | | |
#31964 06/05/2003 2:57 AM | Joined: Jul 2000 Posts: 504 Member | | Member Joined: Jul 2000 Posts: 504 | I assume you are talking about a 52 Chevy Pickup. The normal adjustment to straighten a steering wheel is in the drag link. However, your Chevy Truck has a solid drag link with no adjustment.
Pull the steering wheel and put it back on straight...
You will need to remove the horn button , then the nut that holds the wheel. A steering wheel puller will most likely be needed to release the wheel. They are available to rent or can be purchased in the $ 25 dollar range..
Bill M 53 GMC Hydra-Matic
Home Page http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
#31965 06/05/2003 6:46 AM | Joined: Feb 2000 Posts: 5,223 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,223 | Somethings to consider before just pulling the wheel and repositioning it. The steering boxes are designed to be centered when going down the road. They have a little less clearance in the center position to help keep the truck straight. A little to the left or right and they get easyer. You need to find out if it's the tie rods or the wheel it self thats off. Unhook the draglink from the gear box first, then turn the steering whell all the way to the left. Count the turns till it hits the stop on the right. Now return the wheel to half the amount you just turned it. Is it in the right position now ??? If not, now you can pull the wheel and move it. Joe | | |
#31966 06/05/2003 11:24 PM | Joined: Jan 2003 Posts: 26 Member | | Member Joined: Jan 2003 Posts: 26 | Thanks guys, I'll do all that. | | |
#31967 06/06/2003 2:44 AM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | The tie rods have nothing to do with the center point of the steering. What you might want to do before you pull the steering wheel is go through the steering box adjustment procedure. I think that can skew the centering a little as the wear is taken up. | | |
