| | | Forums66 Topics128,076 Posts1,055,922 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#31886 04/23/2004 11:08 PM | Joined: Apr 2004 Posts: 219 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 219 | Does anyone know the fuel capasity for a stock '66 Panel Dlvry fuel tank?? Thanks in advance.
Jim Sgrig | | |
#31887 04/25/2004 8:23 AM | Joined: Jan 2004 Posts: 158 Member | | Member Joined: Jan 2004 Posts: 158 | Well, I figured I would try to help you out since no one else responded yet. I will email Cliffs Classic Chevrolet and ask him, I would almost garauntee he knows, he specializes in 1955-57 cars, and 1955-1959 trucks. He should get back to me withing a couple days, unless I find out sooner.
Also, could you give me the basic specs on your vehicle:
- Make + Model - Engine - What Size Drivetrain (1/2, 3/4 ton??)
Thanks!
- Shane
- Shane (ChevyToughRebel) 2 Trucks; -1955 3/4 Ton Chevy -1979 3/4 Ton Custom Deluxe 20 4x4 1955 Second Series 3600 GED = Git Er Done
#31888 04/25/2004 12:36 PM | Joined: Apr 2004 Posts: 219 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 219 | Thanks Shane. I did pick up the '66 truck shop manual at Carlisle yesterday. It says the capacity is 20.5 gal.. The tank looks smaller than that. I havn't run it to empty yet. Don't want to take any chances, the gauge is a little squirrelly at times. But, now I have the wiring diagram. Gonna check that out today. If you do contact your friend, see if he agrees with the 20.5 gal.. Thansk again,
Jim Sgrig | | |
#31889 04/26/2004 6:32 AM | Joined: Jan 2004 Posts: 158 Member | | Member Joined: Jan 2004 Posts: 158 | Well, he said he wasnt sure, but he figured 16-18 gallons. I did do some research on ebay, and I couldnt find the right one that corresponded with your panel, but it was something around 20 gallons. So, I think its at least 20 gallons, if the manual says so, then its true as long as its the correct one, and thats the original gas tank. Thought I would try to help, thanks!
- Shane
#31890 04/27/2004 1:20 AM | Joined: Apr 2004 Posts: 219 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 219 | Shane, Thanks for all your help. It is the original tank. The manual says 20.5. I did run it pretty low over the weekend. I'm going to fill it up tomorrow. We'll find out for sure then. I really appreciate all your help. Thanks again,
Jim Sgrig | | |
#31891 04/27/2004 3:27 AM | Joined: Jan 2004 Posts: 158 Member | | Member Joined: Jan 2004 Posts: 158 |
