7 members (NJC, Gray_Ghost, GMCJammer51, Greg_H, 50Chevy3100, 1955 1 Series, 1 invisible),
74
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,073 Posts1,055,908 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#31857 02/28/2005 12:00 AM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I need a breakdown picture or an assembly picture of the rear brake set-up on a 1963 C20 pick-up. I think about any year between 1962 to 1972 3/4 ton would be helpful. Can anyone post one or send me one? Please. Scott | | |
#31858 03/02/2005 4:17 AM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | There's gotta be someone with the manual I need! Scott | | |
#31859 03/02/2005 6:06 AM | Joined: Jun 2004 Posts: 336 Member | | Member Joined: Jun 2004 Posts: 336 | Do you want a picture of the shoes and springs? Or something else such as line routing?
I looked in two books; a Chilton manual for 70-78 trucks and a 1980 Chev Truck service manual (GM factory manual). Both just show "generic" diagrams of the shoes and springs that can be found in any book.
Gord 1954 1/2 ton 235 4 speed
#31860 03/03/2005 6:15 PM | Joined: Apr 2003 Posts: 608 Shop Shark | | Shop Shark Joined: Apr 2003 Posts: 608 | Scott, have you found what you need, if not i prob. have the correct manual out in garage. Also maybe ask nicely and wrenchbender,ret. might just appear  | | |
#31861 03/04/2005 10:20 PM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Thanks for the replies, I haven't been able to get on the site for the last few days while it was down. I need pictures of how the rear brakes are assembled and ready to run. I have an adjuster lever that is three pieces, the main lever, a small piece that is attached on top of the main lever and a spring that connects the two. If anyone has a picture or an exploded view of how this brake set-up installs, I would appreciate it a lot, Scott | | |
