| | | Forums66 Topics128,077 Posts1,056,019 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#31835 04/19/2005 8:54 PM | Joined: Apr 2005 Posts: 4 Junior Member | | Junior Member Joined: Apr 2005 Posts: 4 | I have a gmc swb truck I want to sit it on a newer frame with 4wd is there any good fits with chevy running gear. | | |
#31836 04/19/2005 11:01 PM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | not likely any generic 'good fits'  the frame sizes and mount locations changed w/ every series of truck, so any swap will be a job, especially w/ mounting the front sheet metal where the position and style of rad support is important Bill | | |
#31837 04/20/2005 3:44 AM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | It would be easier to adapt 4WD to your original frame, Scott | | |
