| | | Forums66 Topics128,268 Posts1,058,393 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#31825 04/06/2005 2:42 AM | Joined: Mar 2004 Posts: 71 Member | | Member Joined: Mar 2004 Posts: 71 | Can you safely jack up from underneath to change the motor mounts or do you need to lift from the top? Any other tips? Thanks. | | |
#31826 04/06/2005 4:03 AM | Joined: Mar 2002 Posts: 9,116 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,116 | Which ones are you talking about? In the general the answer is yes. You have to be careful where you apply the lifting force and only move it enough to get the job done. | | |
#31827 04/06/2005 6:02 AM | Joined: Mar 2004 Posts: 71 Member | | Member Joined: Mar 2004 Posts: 71 | i'm planning on replacing both the front and rears. should i loosen all three before putting the jack to it or is there enough play to do the front and rears separately. | | |
#31828 04/06/2005 10:48 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Trere is enough movement to do one end at a time. put a jack under the oil pan with a wooden block.  They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#31829 04/07/2005 12:31 AM | Joined: Mar 2002 Posts: 9,116 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,116 | It has been a while since I did the front but I just did the rear ones this morning. All you need is enough lift to take the weight off them. The rear ones have two horizontal bolts into the block and one vertical into the cross member. Take the vertical ones out first and then the horizontzl ones. They have a 5/8" head on them. | | |
#31830 04/07/2005 2:46 AM | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | A 2 x 4 under the oil pan will lift the motor okay. You will have to loosen the rear mounts if you are replacing the front mount so the motor can pivot. Do not lift it more than you need and importantly make certain that the fan does not touch the rad if you are close to start with. My 235 fan sits extrememly close to my rad, in fact too close to even get the fan belt off. In my case I removed the fan blade for room. | | |
