6 members (Ridgeback, Gdads51, carbking, Jon G, 55shaker, 1 invisible), 61 guests, and 2 robots.
Topics128,268
Posts1,058,391
Members48,485
#31825 04/06/2005 2:42 AM
Can you safely jack up from underneath to change the motor mounts or do you need to lift from the top? Any other tips? Thanks.
#31826 04/06/2005 4:03 AM
Which ones are you talking about? In the general the answer is yes. You have to be careful where you apply the lifting force and only move it enough to get the job done.
1951 1 Ton Completed
#31827 04/06/2005 6:02 AM
i'm planning on replacing both the front and rears. should i loosen all three before putting the jack to it or is there enough play to do the front and rears separately.
#31828 04/06/2005 10:48 PM
Riding in the Passing Lane
Trere is enough movement to do one end at a time. put a jack under the oil pan with a wooden block. smile
1972 Chevy c10 Cheyenne Super
#31829 04/07/2005 12:31 AM
It has been a while since I did the front but I just did the rear ones this morning. All you need is enough lift to take the weight off them. The rear ones have two horizontal bolts into the block and one vertical into the cross member. Take the vertical ones out first and then the horizontzl ones. They have a 5/8" head on them.
#31830 04/07/2005 2:46 AM
A 2 x 4 under the oil pan will lift the motor okay. You will have to loosen the rear mounts if you are replacing the front mount so the motor can pivot. Do not lift it more than you need and importantly make certain that the fan does not touch the rad if you are close to start with. My 235 fan sits extrememly close to my rad, in fact too close to even get the fan belt off. In my case I removed the fan blade for room.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
