5 members (TUTS 59, wilbur53, Jon G, Gdads51, 1 invisible), 85 guests, and 1 robot.
Topics128,131
Posts1,056,373
Members48,441
#31722 06/02/2004 4:45 PM
is there a "bolt in" overdrive transmission that will replace the original 3 speed in a 54 chvy pu (torque tube)?
54 3100 w/62 235 "Yosemite Sam"
Born a Jay Hawk, raised an Okie and resurrected in Texas!http://community.webshots.com/user/djed50
Would someone here chime in and help on this. All that I know is to get an o.d. tranny out of a car.
TTT
Fred
52 3600
69 C-10
Y
Y Offline
From the literature I have seen, Borg Warner was making the overdrive trannies from the mid '30's on. But I have never seen one, nor heard of anybody, with the torque tube setup and O/D prior to 1955.
At one time there was a firm that would modify the overdrive tranny by adding a different rear bearing retainer housing so it would mate to the torque tube. At the same time, I believe the torque tube itself needed to be shortened. The book "How to Restore your Chevrolet Pickup" has a chapter on this now unavailable service.
Bolter Kimo scored a "Truckstell" overdrive unit which I believe is a form of auxiliary transmission in addition to the stock unit. He has a thread here on that.
Probably the best bang for the buck is to go open driveline with a T-5, or if you want to keep the torque tube get 355.1 gears from Patrick. We've beat this topic up quite a bit here if you do a search there are some good reads. wink
I seem to remember a 41 Chevy car with Overdrive when I was a kid, but I have no specifics.
Professional Novice
again thanks for info. i had checked out all the t-5 stuff but guess i was just "wishing and hopeing" there was a simple way to get a little high end speed. looks like new ring and pinion is the simplest way if i plan to keep the torque tube.
I believe it was Ruckstell(sp) who made an OD or 2 speed unit that was bolted to the rear end using some sort of an adapter to hook up the torque tube. I actually saw one in place on a 38 Chevy car.I've seen them for sale, big bucks, might be more economical to ditch the torque tube and go with an open driveline and a tranny of your choice.I did this on two of my trucks, fairly simple job.
truckedup - what model of donor car did you put under your other vehicles? camero, nova etc?? did you keep the original front end?
