3 members (Gdads51, TUTS 59, 1 invisible), 119 guests, and 8 robots.
Topics128,088
Posts1,056,124
Members48,435
#31714 08/26/2003 4:52 PM
Junior Member
Junior Member
I have the chance to buy a good T-5 tranny cheap. I have been told that all you have to do is cut the input shaft about 1/2 inch and then it bolts directly into a 50 chevy bell housing with a 235ci with no other modifications. Is this true? Are flywheel or clutch mods necessary? The tranny is out of a 1988 chevy S-10 with a mechanical speedo. I have a 3.90 1957 chevy rear end. Will this be a good match as far as ratio's for HWY driving?
Joe
#31715 08/26/2003 7:03 PM
"MONGO"
"MONGO"
Chech out the Tech Tips Section of this site:
http://www.stovebolt.com/techtips/t5tranny.htm
http://www.stovebolt.com/techtips/t5tranny2.htm
Also my recent posts on this swap in my 53'
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=2;t=005039
And if you decide to not go with it, I'll buy that T5 wink
MONGO
Mongo's Garage
Vintage GM Truck's & Parts
https://mongosgarage.com
#31716 08/26/2003 7:50 PM
Junior Member
Junior Member
KCMongo, I looked at the tech tips but they do not answer my two questions.
1. Do you have to change out the clutch?
2. Do you need to cut off about 1/2 inch of the front input shaft in order to get the tranny to seat to the bellhousing?
I am a novice when it comes to matching these things up. Looking at Jim Carter's tech article on the T-5 makes it seem like you don't change anything other than cutting the input shaft down. That's all
Joe
#31717 08/27/2003 5:02 AM
50 Cevy , I put a T-5 in my 41 , It is'nt that hard. You do need to grind some off the input shaft , and you will need to get a new clutch disc. And probably there won't be enough splines on the input shaft to completly release the clutch. But , you can get past that prety easy , either add splines to input shaft , or grind off some of the splines on the cluth disc. I recently herd that a Jeep Cherokee disc will fit without modifications. Good luck
Don
#31718 08/27/2003 7:42 PM
"MONGO"
"MONGO"
1.I kept the flywheel and presure plate I already had and bought a Disc that was slightly smaller but has the correct spline for the t5. My truck had a 10 inch clutch on it and I found a clutch at O'Really, Part number RCF4201 it's like 9 7/8 or something very close. Also If you have a 9 Inch Clutch you can use an RCF4190 I believe, It's just under 9 and has the correct splines. I have had no problem disengaging the clutch with this setup, the center part of the disc that hooks to the input shaft looks the same as the one off my old 3 speed (Just diff, Spine).
2. I think we cut 3/8th of the Input shaft and 1/2 inch of the shaft sleeve. Then bored the mount holes out to take the old bolts. You'll also need to put bolts with lockwashers and nuts on the bottom mounts as the old one's screwed into the old tranny and now you just have holes.
Once you get your old tranny out sit them side by side and make the T5 match your old one as far as trimming the input and sleeve goes.
I haven't seen Carters Tech Article could you link me please as I can't find it.
MONGO
Mongo's Garage
#31719 08/29/2003 9:24 PM
It sounds like the clutch plate you used , worked a lot better than the one I used,Mongo. I wished I had used that one. I used the "11" inch S-10 van clutch disk, it works fine, but I already know when its time to replace it , I'll have problems all over again. It was not an easy clutch to get when I got it. I had forgoten to mention the through out bearing sleeve had to be shortened in my other post. I did as Mongo did putting trannys side by side and making them look the same, then I stabed it without clutch or presure plate to make sure all was well. Good luck
Don
#31720 08/29/2003 9:41 PM
Here's the Jim Carter S-10 transmission "Speed Up" article:
http://www.oldchevytrucks.com/cgi-bin/htmlos.cgi/0030.2.2819006815120385750
Tim
#31721 09/01/2003 4:02 PM
Just a question re: the T5 tranny: Will it bolt to a 216? That's what is in my 49 GMC 3/4 (Canadaian built). Also, how easy will it be to change the drive shaft? I have a torque tube for about 18 inches, a bearing, then an open drive line. I am guessing that the shaft is long enough to need the extra bearing. Will I have to change the bearing, or is there a way to just change the forward shaft?
