4 members (Cosmo, dt235sd, Gray_Ghost, Gdads51), 84 guests, and 2 robots.
Topics128,060
Posts1,055,840
Members48,427
#31614 10/04/2004 3:38 PM
I've seen many questions on this board regarding contaminated fuel causing carb problems and fuel filters. I've solved this problem by purchasing from JC Whitney a perma-cool fuel filter/Water separator. Fuel contamination is a fact of life. I mounted it just outside on the frame near where it comes out of the tank, running the lines up over the frame. The filters have a water drain and are a 2 micron filter. By far the best filter I've tried. I know I have crap in the fuel tank -even after cleaning however whats different now is I don't care.
"Drugs are money, money is power, power is security." - Kent Heiner
Nedrow population 2212
Carbon footprint family of 2/11 tonnes of CO2/yr
Does it have a collection cannister which would let you know if ur gettin water?
Buzz'n Half Dozen
#31616 10/08/2004 11:11 PM
There is a petcock on the bottom of the filter.
#31617 10/08/2004 11:51 PM
I shudda asked my question better--have you collected much water out of the gas? I have had similar thots as you and wonder how effective these filters are, Thx for the response. smile
Buzz'n Half Dozen
#31618 10/09/2004 11:34 PM
Very little water, however this filter stopped all the carb problems with contaminates.
