4 members (Otto Skorzeny, Tiny, 2 invisible), 100 guests, and 4 robots.
Topics128,142
Posts1,056,478
Members48,441
#31590 05/08/2005 3:34 AM
Apprentice
Apprentice
EXHAUST MANIFOLD ON OUR 48 FIRETRUCK WAS LEAKING AT 2nd EXHST PORT SO WE REPLACED GASKET
IT LEAKS AS BAD AS EVFR IN SAME PLACE
CAN IT BE TRUED
WILL INTAKE STILL FIT IF EXHST IS TRUED
#31591 05/08/2005 3:57 AM
You can true the manifold by milling (removing the material on the ports that are out of the plane of the surface) the faces of the exhaust ports. A good machine shop should be able to do that.
#31592 05/08/2005 6:54 PM
Apprentice
Apprentice
I had the same problem. I ensured there was a good matting surface between the intake and the exhaust manifold and bolted them together. I then had the machine shop mill both intake and exhaust at the same time. I did have to grind the rings a little, but it worked perfect. The machine shop tech said that was not a normal way to have it milled, but it flat and true.
Jim
#31593 05/13/2005 12:37 AM
I had the same problem on my 62-235 c.i. engine. Took the manifold to a machine shop and found that the exhaust manifold had to be replaced as it had been milled too much. Found a used manifold and took it apart for milling. Put the intake and exhaust back together but left the two parts slightly loose until they were installed on the truck. Then tightened everything down...no more leaks!! Hope this helps.
Green Machine
