| | | Forums66 Topics128,108 Posts1,056,227 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#31590 05/08/2005 3:34 AM | Joined: Sep 2004 Posts: 31 Apprentice | | Apprentice Joined: Sep 2004 Posts: 31 | EXHAUST MANIFOLD ON OUR 48 FIRETRUCK WAS LEAKING AT 2nd EXHST PORT SO WE REPLACED GASKET IT LEAKS AS BAD AS EVFR IN SAME PLACE CAN IT BE TRUED WILL INTAKE STILL FIT IF EXHST IS TRUED | | |
#31591 05/08/2005 3:57 AM | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | You can true the manifold by milling (removing the material on the ports that are out of the plane of the surface) the faces of the exhaust ports. A good machine shop should be able to do that.
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | |
#31592 05/08/2005 6:54 PM | Joined: Jul 2003 Posts: 38 Apprentice | | Apprentice Joined: Jul 2003 Posts: 38 | I had the same problem. I ensured there was a good matting surface between the intake and the exhaust manifold and bolted them together. I then had the machine shop mill both intake and exhaust at the same time. I did have to grind the rings a little, but it worked perfect. The machine shop tech said that was not a normal way to have it milled, but it flat and true.
Jim
#31593 05/13/2005 12:37 AM | Joined: Feb 2001 Posts: 81 Shop Shark | | Shop Shark Joined: Feb 2001 Posts: 81 | I had the same problem on my 62-235 c.i. engine. Took the manifold to a machine shop and found that the exhaust manifold had to be replaced as it had been milled too much. Found a used manifold and took it apart for milling. Put the intake and exhaust back together but left the two parts slightly loose until they were installed on the truck. Then tightened everything down...no more leaks!! Hope this helps.
Green Machine
