| | | Forums66 Topics128,193 Posts1,057,255 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#31417 08/01/2004 4:23 PM | Joined: Jul 2004 Posts: 18 Junior Member | | Junior Member Joined: Jul 2004 Posts: 18 | I have a 41 1/2 PU with a 4 speed trani and torque tube. On the end of my torque tube there is a sleeve over it increasing the outside dia. to 2 1/4.I have not seen this sleeve on any other torque tubes. I am looking for the gasket which goes on the end of the universal housing. which seal the housing to the torqe tube.
41 1/2 ton
don't force it get a bigger hammer
#31418 08/01/2004 6:59 PM | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Chevs of the 40s has a kit with all the seals/gaskets you need. You should pick up a manual also, shows what goes where. Best of luck | | |
#31419 08/01/2004 7:10 PM | Joined: Jul 2004 Posts: 18 Junior Member | | Junior Member Joined: Jul 2004 Posts: 18 | I already got the gasket rebuild kit from J Carter but the gasket for the universal enclosure is for 2" torque tube. my enclosure is set up for a 2 1/4" torque tube.
41 1/2 ton
#31420 08/02/2004 1:47 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | I'd pick up the phone and ask Carter why the parts don't fit.
Fred 52 3600 69 C-10
