6 members (Bills54, stoveboltgator, dt235sd, TexasA&M48Truck, klhansen, HandyAndy), 105 guests, and 1 robot.
Topics128,047
Posts1,055,534
Members48,424
#31347 11/26/2004 2:20 AM
hey guys, i was looking at pics of the "YardDog" in the gallery, and couldn't help but think how nice it'd be to have a winch and a boom on the back of one of my old pickups. is there any special tranny that has a PTO output? or..is there someway to hob-knob one together? i'l appreciate any input..i'm really interested now. lol. thanx for your time.
SamWise
.for every 1 mile of road theres 2 miles of ditches.
1969 K20 , with a '67 front clip. fleetside. 292, 3x1 offy, headers. sm465 4spd. getting put back together, almost ready for paint.
doing it all myself.
19 and lovin' it.
"proper" is so over-rated.
.later days.
.sam.
#31348 11/26/2004 4:54 AM
Sam, if your truck has an SM420 transmission (4spd with granny first gear) it will have a plate on the side of the transmission case held on with 6 bolts. It is located on the drivers side of the transmission.
Here is a picture of what the plate looks like (behind the exhaust pipe)
I have picked up several PTOs that bolt onto the side of the transmission, the units I have are made by Chelsea and are used to drive a hydraulic pump via. a short driveline. They could just as easily drive a winch through the proper drivetrain. A short linkage goes to the cab, just press in the clutch, pull on the lever to engage the PTO and ease out the clutch . . . works great!
Life's short - don't waste it.
#31349 11/26/2004 5:09 AM
All the 4-speed truck transmissions have a place for a PTO. If you're going to use a capstan-type winch, you'll probably need the type with forward and reverse positions on it. If you can find a winch from an old wrecker, there should be forward and reverse clutches on it, and you can get by with a single-direction PTO.
#31350 11/26/2004 8:01 PM
thanx for the replys guys! that helps me over the first step..my 68 has a sm420. or atleast a 4 speed granny. so we'll see. and i was discussing it with my dad, and he said that if we could figure out the PTO, we'd just run a hydraulic pump. so, how much do those chelsea PTO's run? or...we have most of a farmall tractor out back, with a PTO shaft i'm sure, so..is there a way to make that work? thanx for your help guys!
SamWise
19 and lovin' it.
.later days.
.sam.
#31351 11/26/2004 8:25 PM
They pop up on ebay all the time . . .
Presently 10 bucks apiece
The gear that they interface with in the transmission is a helical cut gear. Make sure that you do not get a PTO with a straight cut gear.
[img]http://i20.ebayimg.com/02/i/02/e6/e5/cb_1_b.JPG[/img]
The one on the right is correct for your tranny - the one on the left might work? :confused:
This one is incorrect.
[img]http://www.geocities.com/lambson1/4001.jpg[/img]
