8 members (Tyler Watts, Hotrod Lincoln, Joe H, Gray_Ghost, Forty9, cmayna, JW51, NJC),
82
Mod | | | Forums66 Topics128,064 Posts1,055,860 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#31128 08/18/2004 6:43 PM | Joined: Aug 2004 Posts: 20 Member | | Member Joined: Aug 2004 Posts: 20 | Is their a place online where I can enter the serial # off the truck to find out more information about it? Thanks Kyle | | |
#31129 08/18/2004 6:49 PM | Joined: Mar 2002 Posts: 553 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 553 | Yes, click on the banner at the top of this page. | | |
#31130 08/18/2004 6:50 PM | Joined: Aug 2004 Posts: 20 Member | | Member Joined: Aug 2004 Posts: 20 | Thanks, i figured it was here somewhere, im new to the site and still learning it. | | |
#31131 08/18/2004 6:53 PM | Joined: Aug 2004 Posts: 20 Member | | Member Joined: Aug 2004 Posts: 20 | I got a number from the drivers side door hinge area. Is this what I am looking for to find out infromation on the model and year of the truck? | | |
#31132 08/18/2004 6:58 PM | Joined: Aug 2004 Posts: 20 Member | | Member Joined: Aug 2004 Posts: 20 | Also, where is the number usually located on the motor? | | |
#31133 08/18/2004 7:01 PM | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | Kyle,
Engine # is behind the distributor on a 216-235, on the block. Should be a little flat spot, all covered with grease if your truck is untouched.
What year, make, model and # of cylinders are we talking about? | | |
#31134 08/18/2004 7:04 PM | Joined: Aug 2004 Posts: 20 Member | | Member Joined: Aug 2004 Posts: 20 | Its a 1948 Chevrolet Loadmaster Flatbed with an inline six. | | |
#31135 08/18/2004 7:08 PM | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | Yep....look at the distrib. Clean the grease off on the firewall side. Should be #s under there. If you have the acorn nuts on the top of the valve cover, you are looking at a 216/235. If none are present, someone has swapped out the 6 for a newer one.
I don't know about your 48 since it is an AD, but a serial number plate on a 46 is passenger side inside the engine compartment on the cab. | | |
#31136 08/18/2004 7:13 PM | Joined: Aug 2004 Posts: 20 Member | | Member Joined: Aug 2004 Posts: 20 | Thanks for the help, I will see what I can find. | | |
#31137 08/18/2004 11:26 PM | Joined: Nov 2003 Posts: 117 Member | | Member Joined: Nov 2003 Posts: 117 | Kyle, the serial number truck on your truck should be on the drivers door post. It is at the bottom of the tag.
Winona 1949 3100 5 Window Deluxe Cab
#31138 08/18/2004 11:27 PM | Joined: Nov 2003 Posts: 117 Member | | Member Joined: Nov 2003 Posts: 117 | Kyle, the serial number truck on your truck should be on the drivers door post. It is the serial number at the bottom of the tag.
#31139 08/19/2004 5:11 AM | Joined: Aug 2004 Posts: 20 Member | | Member Joined: Aug 2004 Posts: 20 | I got 5RKA-1093 off the drivers side door post, could anyone please tell me a little about my truck, or where I can use that # to find information? | | |
#31140 08/19/2004 1:36 PM | Joined: Jun 2000 Posts: 454 Shop Shark | | Shop Shark Joined: Jun 2000 Posts: 454 | Kyle, I always use Don Moen's Ultimate Recycler Page to do the serial number breakdown. 5 = Kansas City, MO assembly plant R = This doesn't work, it should be F for 1948 K = Series 4400 (1 1/2 ton) A = Assembled in January 1093 = 92nd truck off the line (sequential numbers start with 1001)
Jeff Nelson
"Beer is proof that God loves us and wants us to be happy." - Benjamin Franklin "Always do right. This will gratify some people and astonish the rest." - Mark Twain
#31141 08/19/2004 3:30 PM | Joined: Aug 2004 Posts: 20 Member | | Member Joined: Aug 2004 Posts: 20 | Thanks Jeff, I also read something on that page in the very fine print about what the "R" stands for. I is the year, but for the 1 1/2 and 2 ton Heavy Duty trucks. I appreciate the help. Kyle | | |
#31142 08/19/2004 6:26 PM | Joined: Jun 2000 Posts: 454 Shop Shark | | Shop Shark Joined: Jun 2000 Posts: 454 | Kyle, Yep, my bad, I forgot to follow the asterisk on Don's page and read "Except 47-52 1-1/2 and 2 Ton Heavy Duty Trucks, which used Q, R, S, T, U, V to designate Year".
Thanks for pointing that out and good luck with your truck.
Jeff Nelson
#31143 08/19/2004 10:38 PM | Joined: Feb 2000 Posts: 268 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 268 | 1093 = 92nd truck off the line (sequential numbers start with 1001) So the first truck off the line would be 1001 right? 92nd truck off the line is 1093? how's that work, which number did they skip? If numbering started at 1000 then that would be right, starting at 1001 just drop 1000 from the number, 93rd truck off this line. A little mistake I use to make too when decoding numbers, but when you see number 1002 and you tell them is was the 1st truck off the line..... the light came on of me then. | | |
#31144 08/20/2004 1:53 AM | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | Kyle,
Did you find your engine serial number? What do you have under the hood of that rig? | | |
#31145 08/20/2004 4:57 AM | Joined: Aug 2004 Posts: 20 Member | | Member Joined: Aug 2004 Posts: 20 | Yes I did, It has a 216 with a wopping 90 HP. Its small for a ton and a half I guess, but it gets the job done. | | |
#31146 08/20/2004 5:25 PM | Joined: Sep 2001 Posts: 581 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 581 | Kyle,
I'd be REALLY surprised if a 11/2 ton ORIGINALLY came with a 216. The 235 would have been standard, me thinks, and is what is referred to as the LoadMaster. An even MORE whopping 93 Horsepower, although I think the Rochester carb and some other "refinements" early in the AD series were supposed to up the HP some - not sure when that happened without my lit-tra-ture in front of me.
My guess would be someone swapped in the 216 at some point.
Of course, my boss tells me I'm dumber than a bag of hammers, so take what I say with a grain of salt . . . ;-)
-Michael | | |
#31147 08/20/2004 5:54 PM | Joined: Aug 2004 Posts: 20 Member | | Member Joined: Aug 2004 Posts: 20 | Ill see if I can find out if it was swapped. My greatgrandpa was the one who first perchased the truck, so I should be able to find out. | | |
#31148 08/20/2004 6:19 PM | Joined: Jun 2000 Posts: 454 Shop Shark | | Shop Shark Joined: Jun 2000 Posts: 454 | Originally posted by Jolly: 1093 = 92nd truck off the line (sequential numbers start with 1001) So the first truck off the line would be 1001 right? 92nd truck off the line is 1093? how's that work, which number did they skip? If numbering started at 1000 then that would be right, starting at 1001 just drop 1000 from the number, 93rd truck off this line. A little mistake I use to make too when decoding numbers, but when you see number 1002 and you tell them is was the 1st truck off the line..... the light came on of me then.Oh picky, picky, picky Sorry about that, you're absolutely correct. Are you sure that number 1002 isn't the first one off the line :p ?
Jeff Nelson
