6 members (3800GUY, David Bush, Oswald, Wally / Montana, Rusty Heaps, 1 invisible), 34 guests, and 2 robots.
Topics128,074
Posts1,055,911
Members48,429
#30935 12/10/2002 5:47 AM
would love to put modern roller bearings on the front of my task force trucks - I've seen'em advertized from 2 repro parts places, but haven't been able to find'em thru bearing places using the ball bearing #s/sizes as reference. anybody know what the #s are for these bearings?
#30936 12/10/2002 6:22 AM
NAPA has wheel bearings for your trucks, but it doesn't say if they're ball or roller. Might be worth a call.
BRG-B44 (Inner) $81.99
BRG-B45 (Outer) $72.49
1955 First Series GMC 250 1-Ton Panel
Mr. Hedgehog - Follow the build
If you can't laugh at yourself, I'll laugh at you.
#30937 12/10/2002 6:59 AM
cool - thanx for the lead. never thought of NAPA being online. the ball brng #s I've got installed now are B52 [inner] and B67 outer [was B01 originally], so worth a check.
#30938 12/12/2002 4:02 AM
nope - all above numbers are ball, not roller. gonna try another round of lookin for'em by usin the ball bearing measurements, but if anyone comes up w/ more numbers pls post!
#30939 12/12/2002 9:15 AM
The problem stems from the fact that the leather inner grease seals are press fit into the bearing race. The spindle also has a unique taper. The new roller bearings in the kits are custom specified and not readily available from a bearing supplier. They also use neoprene instead of leather. There is really nothing inherantly wrong with the ball bearings if you keep them greased and adjusted and don't run really wide tires with power steering. You can wear out at least two sets of ball bearings before you will recover the cost of the roller bearing set, at which point the rest of the truck will be worn out and so will the roller bearings.
Paint & Body Shop moderator
