6 members (Jon G, klhansen, dt235sd, Tim Canfield, Oswald, 1 invisible), 92 guests, and 2 robots.
Topics128,035
Posts1,055,445
Members48,422
#3086 12/19/2002 7:19 PM
What is the torque setting on the exhaust manifold bolts for my "66 250 c.i. p.u?
#3087 12/19/2002 8:31 PM
1/4 turn past snap; then back it off. :p
I have no idea but someone here will have that. Have a good day!
Thomas Mott
1949 GMC 250
1957 Dodge COE c-700
1959 Chris Craft 17' w/big journal 327 for more power
#3088 12/20/2002 1:03 PM
off the side of my head I say it is 45lb/feet.
Start at the middle two bolts and slowly work your way back and forth to the outer bolts/nuts.
Do them at 15lb/ft, then 30lb/ft, then final 45lb/ft.
after it has been fully warmed to operating temp and has been driven, recheck them at 45lb/ft. cool
#3089 12/20/2002 1:37 PM
I would recommend that you purchase a chiltons or Motors manual, that way you dont have to worry too much about busting you knuckles after you bust a nut.
Another quality post.
Real Trucks Rattle
#3090 12/21/2002 7:48 AM
The manual reads, "End clamp bolts 20, center bolts 30 ".
#3091 12/25/2002 8:55 PM
Seon is correct, I looked in my Chiltons and it says as a foot-note, center bolts 25-30 and end bolts 15-20
