3 members (RLB, Oswald, GRNHydra),
86
Mod | | | Forums66 Topics128,030 Posts1,055,430 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2002 Posts: 7 Member | | Member Joined: Jan 2002 Posts: 7 | What is the torque setting on the exhaust manifold bolts for my "66 250 c.i. p.u? | | | | | Joined: Dec 2001 Posts: 31 Member | | Member Joined: Dec 2001 Posts: 31 | 1/4 turn past snap; then back it off. :p
I have no idea but someone here will have that. Have a good day!
Thomas Mott 1949 GMC 250 1957 Dodge COE c-700 1959 Chris Craft 17' w/big journal 327 for more power
| | | | | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | off the side of my head I say it is 45lb/feet. Start at the middle two bolts and slowly work your way back and forth to the outer bolts/nuts. Do them at 15lb/ft, then 30lb/ft, then final 45lb/ft. after it has been fully warmed to operating temp and has been driven, recheck them at 45lb/ft.
| | | | | Joined: Dec 2002 Posts: 3,439 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,439 | I would recommend that you purchase a chiltons or Motors manual, that way you dont have to worry too much about busting you knuckles after you bust a nut.
| | | | | Joined: Jan 2002 Posts: 244 Shop Shark | | Shop Shark Joined: Jan 2002 Posts: 244 | The manual reads, "End clamp bolts 20, center bolts 30 ". | | | | | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Seon is correct, I looked in my Chiltons and it says as a foot-note, center bolts 25-30 and end bolts 15-20
