5 members (55shaker, Gdads51, Ponchogl, DadsFirstPickup, stlcardinalsguy), 125 guests, and 1 robot.
Topics128,054
Posts1,055,782
#30781 07/29/2004 2:27 AM
Which way does the shiny side go on the gasket between the manifolds?
Winona
1949 3100 5 Window Deluxe Cab
#30782 07/29/2004 3:18 AM
put the shiney side to the colder face , ie , the intake side.
#30783 07/29/2004 3:36 AM
Thanks!!
Winona
#30784 07/29/2004 7:59 PM
A bit of advice on manifold installation. Chevy had problems with leaky manifolds on their inline six engines due to the design. Several years back I started installing them with Ultra-copper RTV. I place a thin bead (about 1/4" thick) between the gasket and the manifold, then bolt the manifold on and tighten the bolts. Inspect for gaps, and redo with more sealant if there are any. Don't start the engine for 24 hours, allowing the RTV time to cure. At that time you can trim away the excess with a sharp knife or razor blade if desired.
I haven't had a leaky manifold since.
Fred
52 3600
69 C-10
#30785 07/29/2004 8:35 PM
Fred, do I put the RTV on all manifold gaskets (intake, exhaust, and in-between)?
Winona
#30786 07/29/2004 9:35 PM
Riding in the Passing Lane
I have used this methed many times. I put it on
all gasket surfaces.
1972 Chevy c10 Cheyenne Super
#30787 07/30/2004 4:17 AM
Quote
Yes. What I do is apply the sealant directly to the manifold mating surfaces.
Fred
52 3600
69 C-10
#30788 07/30/2004 8:53 PM
Thanks, guys. Slowly, but surely, I'm learning.
Winona
#30789 08/01/2004 8:56 PM
:confused: :confused:
Hey, Guys, what happens if you don't turn the "shinny" side out against the manifold?
#30790 08/01/2004 9:11 PM
Just a reminder;
Don't tighten the bolts connecting the two manifolds together until you have tightened the bolts between the manifolds and the head.
Forgetting this will result in cracked manifolds and leaks.
'31 Chevy 1 1/2 ton,
'42 GMC 2 1/2 ton 6x4,
'52 GMC 2 1/2 ton 6x6,
'53 GMC 5 ton
#30791 08/02/2004 12:33 AM
Ok - let me try again - what I meant is: What happens if you turn the "shinny" side in, against the head?
#30792 08/02/2004 12:52 AM
Quote
On V8s (ok, "twin-4s") I've used 2 sets of FelPro exhaust manifold gaskets many times. I put them back to back so that there's a shiny side facing the header and one facing the head. Works fine. I don't see why you couldn't do that with your I6 gasket. Matter of fact, that's what I'd reccomend doing...using 2 gaskets back-to-back.
#30793 08/02/2004 9:03 PM
Quote
That's how we all got where we are today. wink Lot's of questions and lot's of experimentation, even a few things destroyed in the process. Best if you can learn from someone else's mistakes. It's usually cheaper that way.
I really like these forums where people are willing to share their hard-earned knowledge. Makes it so much better for those without as much experience to succeed. I would love to be in a position where I did nothing but advise people in matters such as this. Unfortunately, I have to keep some cash flowing in to support my hobbies.
Fred
52 3600
69 C-10
