1 members (1 invisible),
100
Mod | | | Forums66 Topics128,265 Posts1,058,366 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#30697 12/21/2004 4:36 AM | Joined: Dec 2003 Posts: 9 Member | | Member Joined: Dec 2003 Posts: 9 | Just wondering if anybody has installed a Pontiac 326-455 in your truck? I'm considering a Pontiac since I have a 326 and a 400 here in my shop. Thinking about a 4 speed O/D automatic as well. Any comments are appreciated! Dean | | |
#30698 12/21/2004 4:38 AM | Joined: Dec 2003 Posts: 9 Member | | Member Joined: Dec 2003 Posts: 9 | My truck is a 1952 3600 5 window.... | | |
#30699 12/21/2004 5:10 AM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | | | |
#30701 12/21/2004 10:29 AM | Joined: Aug 2004 Posts: 196 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2004 Posts: 196 | 1956 gmc came with pontiac 326 with 4 spd hydromatic they hauled === | | |
#30702 12/22/2004 7:53 AM | Joined: Feb 2000 Posts: 5,265 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,265 | It shouldn't be a problem other then the four speed automatic. Pontiac never used one so some sort of adapter will be required. About the only bolt in I can think of is a multi bolt pattern case Turbo 350 with lock up converter. The late 70's used this case. It fits BOP, Caddy, and Chevrolet. As far as the motor goes, don't waste your money on the 326. Parts cost just the same for the 400 and you will much happier with the bigger cubic inch motor. I would sell both of them and look for a 455, then you would have something that would haul @&%!
Joe Hand, ex-Pontiac racer. | | |
#30703 12/22/2004 2:12 PM | Joined: Jun 2004 Posts: 19 Junior Member | | Junior Member Joined: Jun 2004 Posts: 19 | I had a 1960 Pontiac Catalina 2 dr hard top had the 389 and a 4 speed automatic. Surprised me when I first got to drive it. Shifted once, then twice, then a third time around 45mph. I expected it to be a three speed. It would run down the road mighty fine. | | |
#30704 12/23/2004 5:12 AM | Joined: Mar 2004 Posts: 154 Member | | Member Joined: Mar 2004 Posts: 154 | i say...go for it! the 455 was a monstrous engine. have one out back in a 71 Olds Delta 88. talk about a tank. stories are you could measure your speed by the way the gas guage dropped, and tires were a weekly event. LoL. but yeah. go for it. theres no challenging the 455 rocket for torque. just the oiling system was a drawback..but hey. take the god with the bad.
.SamWise. 1969 K20 , with a '67 front clip. fleetside. 292, 3x1 offy, headers. sm465 4spd. getting put back together, almost ready for paint. doing it all myself. 19 and lovin' it. "proper" is so over-rated. .later days. .sam.
#30705 12/24/2004 1:20 AM | Joined: Aug 2004 Posts: 196 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2004 Posts: 196 | thats true about the gas i had a66 gto with a 455 super duty 4 spd. on a week end id burn 2 tanks of gas in one night never had a car sence that would do that i could also burn the tires off the rims with the car not even moving | | |
#30706 12/27/2004 2:52 PM | Joined: Aug 2003 Posts: 19 Junior Member | | Junior Member Joined: Aug 2003 Posts: 19 | Well, a 200r4 should have a universal bolt pattern and bolt up to a poncho. However, its lifespan would be quite dependant on how the trans was (re)built and the torque put out by your pontiac. The 400 could put a 200r4 in a world of hurt in short order if it was stout and the trans was stock. There are adapter kits for the 700 4r available from places like Summit, and the 700s tend to stand up but a lot of that depends on how it was (re)built too. This can be done without too much extra hassle over a sbc so don't get intimidated. | | |
#30707 12/28/2004 1:41 AM | Joined: Feb 2000 Posts: 5,265 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,265 | The 700 won't be a direct bolt in but it can be done. If you build the motor right you shouldn't need overdrive. My dads been dragracing Pontiacs since the mid 50's. He now runs a 71 Lemans wagon with a race built 455. The car weighs 4050lbs and has run as fast as 11.32 @ 116 mph with DOT radials and full exhaust system. Fact he drives it to the dragstrip. It uses a 3.31 gear ratio! Due to the high torque of the motor, it doesn't need a steep gear. You could do the same thing, gear it down and use a tall tire. My little 250 inline can pull a 3.08 with a 29" tall tire as fast as you want to drive. Your Pontiac motor shouldn't have any problem with a 3.08 or 3.23 with a 31" tire. That works out to about 2150 rpm at 65 with a 3.08 or 2275 with a 3.23. Joe | | |
