4 members (TUTS 59, Forty9, mo2cyl, Stovebolt48), 39 guests, and 2 robots.
Topics128,031
Posts1,055,436
Members48,422
#30367 10/06/2002 4:19 PM
Z
Z Offline
ANYONE KNOW THE SEAL NUMBER ON AN SM 420?(YOKE SEAL). TRADED MY OLD 216 FOR THE SM420, WANT TO REPLACE THE REAR SEAL BEFORE INSTALLING. BELEIVE IT IS IN THE 47-53 VINTAGE.
The Amish Connection
51 Chevy 1/2 ton 5 window,Vortec hotrod, no horse
#30368 10/06/2002 5:39 PM
1 Offline
Check out the following, they will either have the part or know where to get it.
web page
#30369 10/07/2002 5:43 PM
I just changed one of these on my truck and found the seal at NAPA. NAPA part #: 22340. Only was about $9.00. The seal I could not locate was the paper gasket for the bearing retainer on the back of the tranny. RTV gasket goop worked good though.
"The Operation of GMC trucks is normally smooth and steady, with no loud rattling, knocking or unusual noises. A good driver will quickly become accustomed to driving a GMC truck and will get the feel of his vehicle regardless of his engineering knowledge."-TM10-1563
#30370 10/08/2002 1:30 PM
Zeker6, I am assuming you are installing this Muncie in an AD? What is your choice for a rear-end?
1953 Chevrolet 1300 - Daily driver
Collecting Vintage Whizzer motorbikes
http://www.whizzerick.com
#30371 10/08/2002 7:53 PM
Z
Z Offline
Used a 78 Camero 3.42 with same (Camero)springs, and fabricated spring mounts. I was awaiting mounting trans to set the rear angle and weld spring pads to rear housing.
