3 members (BC59, dt235sd, Wooley),
124
Mod | | | Forums66 Topics128,162 Posts1,056,936 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#30209 03/16/2004 3:49 PM | Joined: May 2001 Posts: 1,907 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,907 | I got the '48 with its new 261 and Luke's 4.10 rear end on the road last night!! What a great feeling after 18 months. That 261 has a lot more zip than the old 235! I could feel the difference even with the longer gears of the 4.10. More later including pictures! [img] http://www.sandeace.com/48/TruckDrawingThumbnail.jpg[/img] 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
#30210 03/16/2004 4:10 PM | Joined: Feb 2000 Posts: 988 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 988 |
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | |
#30211 03/16/2004 4:47 PM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I'll bet you've still got a grin on your face. Happy haulin'. | | |
#30212 03/16/2004 8:19 PM | Joined: Aug 2000 Posts: 122 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 122 | Congrats Wally, nice to have another AD on the road up here. We will have to go cruizin sometime.
Steve 55 1st Series 3/4 ton
#30213 03/16/2004 9:26 PM | Joined: Oct 2003 Posts: 62 Member | | Member Joined: Oct 2003 Posts: 62 | just got my 261 done 'n runnin too, in a otherwise stock 40 ' half ton. am considering some long trips with it. GREAT ,aren't they?! Have fun(you will). | | |
#30214 03/16/2004 10:40 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Good job, Wally.. Just don't let smokey get you. My 4.10 gears with taller tires makes me go 80 when the speedo reads 65.
Fred 52 3600 69 C-10
#30215 03/17/2004 4:24 PM | Joined: May 2001 Posts: 1,907 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,907 | Thanks for all the help!!!
I like my method of putting bolts, parts, etc. in Zip Lock bags with a card that says what they're for. I cleaned up the garage last night and found one Zip Lock bag that had a C-clip with a card that read "For Torque Tube End." Oops, I guess that holds in the bearing at the lower end of the torque tube. I gotta put that in tonight.
I'm getting together a photo gallery and will post the link when it is finished.
Thanks, again. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
#30216 03/17/2004 10:29 PM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Torque-tube rear end?????? :confused: :confused: :confused:
#30217 03/18/2004 12:29 AM | Joined: May 2001 Posts: 1,907 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,907 | Nope, it says for "Torque Tub End." 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
#30218 03/18/2004 12:44 AM | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | Just sweep it back under the bench...
54 3100 with 235 62 flatbed dump C60 with 261
#30219 03/18/2004 12:57 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Do you have a pic of the part?
#30220 03/18/2004 4:44 PM | Joined: May 2001 Posts: 1,907 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,907 | I'm sure it's the torque tube spring clip bearing retainer. The information about the torque tube is spread out in the shop manual. I found the drawing of the torque under Rear Axle and the info about the ball joint adjustment under the 3-Speed Transmission only. I have a 4-speed. I'll get a picture. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
#30221 03/19/2004 4:07 PM | Joined: May 2001 Posts: 1,907 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,907 | Here's a photo of what I think is the torque tube bearing retainer clip. It's 2 3/4 in. in diameter. Am I right? [img] http://www.sandeace.com/48/BearingRetainerClip.jpg[/img] 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
