1 members (Otto Skorzeny), 85 guests, and 2 robots.
Topics128,162
Posts1,056,936
Members48,458
I got the '48 with its new 261 and Luke's 4.10 rear end on the road last night!! What a great feeling after 18 months. That 261 has a lot more zip than the old 235! I could feel the difference even with the longer gears of the 4.10. More later including pictures!
[img]http://www.sandeace.com/48/TruckDrawingThumbnail.jpg[/img]
Way to go Wally!!!!!!
Brian Moore
1949 3100 5 window Deluxe
"Today is better than yesterday, but not as good as tomorrow"
I'll bet you've still got a grin on your face. Happy haulin'.
Congrats Wally, nice to have another AD on the road up here. We will have to go cruizin sometime.
Steve
55 1st Series 3/4 ton
ape Offline
just got my 261 done 'n runnin too, in a otherwise stock 40 ' half ton. am considering some long trips with it. GREAT ,aren't they?! Have fun(you will).
Good job, Wally.. Just don't let smokey get you. My 4.10 gears with taller tires makes me go 80 when the speedo reads 65.
Fred
52 3600
69 C-10
Thanks for all the help!!!
I like my method of putting bolts, parts, etc. in Zip Lock bags with a card that says what they're for. I cleaned up the garage last night and found one Zip Lock bag that had a C-clip with a card that read "For Torque Tube End." Oops, I guess that holds in the bearing at the lower end of the torque tube. I gotta put that in tonight.
I'm getting together a photo gallery and will post the link when it is finished.
Thanks, again.
Torque-tube rear end?????? :confused: :confused: :confused:
Nope, it says for "Torque Tub End."
Just sweep it back under the bench...
54 3100 with 235
62 flatbed dump C60 with 261
Do you have a pic of the part?
I'm sure it's the torque tube spring clip bearing retainer. The information about the torque tube is spread out in the shop manual. I found the drawing of the torque under Rear Axle and the info about the ball joint adjustment under the 3-Speed Transmission only. I have a 4-speed. I'll get a picture.
Here's a photo of what I think is the torque tube bearing retainer clip. It's 2 3/4 in. in diameter. Am I right?
[img]http://www.sandeace.com/48/BearingRetainerClip.jpg[/img]
