1 members (Hotrod Lincoln),
72
0
Mod | | | Forums66 Topics128,049 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#30119 02/26/2005 6:06 AM | Joined: Jan 2004 Posts: 158 Member | | Member Joined: Jan 2004 Posts: 158 | I just recently got a riding lawnmower and discovered that the spark plug hole is stripped out so the plug wont seal. Its a regular 1 cylinder, gasoline engine. Would the local machine shop be able to fix this? Or is there someting simple I can do to fix this? I tried rethreading the hole and the threads just broke off leaving a smooth hole. Any help or suggestions would be great, thanks! - Shane [email protected]
- Shane (ChevyToughRebel) 2 Trucks; -1955 3/4 Ton Chevy -1979 3/4 Ton Custom Deluxe 20 4x4 1955 Second Series 3600 GED = Git Er Done
#30120 02/26/2005 6:21 AM | Joined: Jan 2005 Posts: 364 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 364 | your local machine shop should be able to install a heli-coil for you. It would be helpful to your shop if you remove the head and just bring it to them. That way you don't get any metal filings in the cyl. I've done quite a few, takes about 15min. depending on the mood your machinist is in.
Keith If it were easy they'd have grade schoolers doing it! | | |
#30121 02/26/2005 6:49 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | You may be able to get a new head for cheaper than getting it fixed, especially if it is a flathead Briggs engine. Check with Roy Boy's (near Washington Square), they have a good stock of parts.
#30122 02/27/2005 6:03 AM | Joined: Jan 2004 Posts: 158 Member | | Member Joined: Jan 2004 Posts: 158 | Yeah, I was told that I could buy a helicoil kit, I might try that and see how it works, if it doesnt and all else fails I will try to search for another head. The wierd thing about this rig is that it has a generator that acts as a starter and turns the motor over, and then has a coil out of a truck, has anyone ever seen anything like this? I wonder if someone added this all on, if not then I will remount everything so its hidden. Thanks for the help all, I will try to get pics of this thing sometime and maybe show everyone! - Shane [email protected]
#30123 02/27/2005 6:26 AM | Joined: Jan 2002 Posts: 622 Member | | Member Joined: Jan 2002 Posts: 622 | If you can find a larger plug that will work, then just bore out the plug hole and re-tap the threads.
delete my account and pictures
#30124 03/03/2005 5:38 PM | Joined: Feb 2000 Posts: 986 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 986 | I had to replace a head on a lawn tractor once. Head and gasket cost me $12. I doubt a helicoil kit will be that cheap.
You should take the head off to put the helicoil in (drill shavings) so why not replace the head.
good luck either way!
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | |
