3 members (Jon G, Otto Skorzeny, 1955 1 Series), 85 guests, and 2 robots.
Topics128,026
Posts1,055,399
Members48,422
#3007 09/25/2003 3:12 PM
I just got my new motor mounts in from Carter's today. I was a little suprised to see that they were from India. Not only that, they do not have the spacer that goes all the way through the rear transmission mount to the lower mount. The front mount is just the rubber, not the metal cover that was on the original.
Question: Can I dig out the rubber from inside the metal cover of the original front mount and then insert the new rubber? Also, my maintenance manual shows a lower rubber piece that goes below the front cross member. I did not receive one with the mount from Carter's and I cant find anything like that from when I removed the engine in the first place.
Anyone have any ideas?
Tom
Whats down in the well comes up in the bucket, so watch who's KoolAid you drink.
#3008 09/25/2003 4:48 PM
What's the model?
What's the year?
#3009 09/25/2003 5:55 PM
55 1st GMC 3/4 ton (150) 270 il 6
#3010 09/25/2003 7:05 PM
Can't answer the whole thing, but you do need the metal cover to keep the oil off the front mount. Either salvage it or make a new one.
Fred
52 3600
69 C-10
#3011 09/25/2003 9:52 PM
The metal cover is a shield that does not come with the mount. Your mount and shield should be able to be separated fairly easy.
The lower piece of rubber should be replaced as well. I need to find the same piece but haven`t looked yet :rolleyes:
