0 members (),
61
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2001 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2001 Posts: 92 | I just got my new motor mounts in from Carter's today. I was a little suprised to see that they were from India. Not only that, they do not have the spacer that goes all the way through the rear transmission mount to the lower mount. The front mount is just the rubber, not the metal cover that was on the original.
Question: Can I dig out the rubber from inside the metal cover of the original front mount and then insert the new rubber? Also, my maintenance manual shows a lower rubber piece that goes below the front cross member. I did not receive one with the mount from Carter's and I cant find anything like that from when I removed the engine in the first place.
Anyone have any ideas?
Tom
Whats down in the well comes up in the bucket, so watch who's KoolAid you drink.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | What's the model? What's the year? | | | | | Joined: Feb 2001 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2001 Posts: 92 | 55 1st GMC 3/4 ton (150) 270 il 6
| | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Can't answer the whole thing, but you do need the metal cover to keep the oil off the front mount. Either salvage it or make a new one.
Fred 52 3600 69 C-10
| | | | | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | The metal cover is a shield that does not come with the mount. Your mount and shield should be able to be separated fairly easy. The lower piece of rubber should be replaced as well. I need to find the same piece but haven`t looked yet :rolleyes:
