9 members (Hotrod Lincoln, 55shaker, MickeyP, 50Chevy3100, frogfarmer, Pre '68 Dave, 3 invisible),
107
Mod | | | Forums66 Topics128,260 Posts1,058,322 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#30079 10/31/2002 8:05 PM | Joined: Jan 2001 Posts: 428 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 428 | I'm ready to put the head on my 51 216 and have 3 different types of head gaskets and was wondering what would be the best to use. I have a copper one with a fiber core,a steel one with a fiber core, and just a fiber one with the steel rings around the pistons and water jackets. Anyone offer any opinions or suggestions? Also while I've got your attention, I've done plenty of valve lash settings on a hot engine,but what should the valves be set at on initial startup of a fresh motor? New stock solid cam and lifters. Should they be set a little looser than the usual hot settings?Thanks, Bob | | |
#30080 10/31/2002 8:26 PM | Joined: Dec 2000 Posts: 506 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 506 | Rule of thumb is with cast iron head and block .002 tighter than book. Would be different other way if the head was aluminum but that isn't possible with this engine. t
"Drugs are money, money is power, power is security." - Kent Heiner Nedrow population 2212 Carbon footprint family of 2/11 tonnes of CO2/yr
