4 members (MickeyP, GA Boy, dgrinnan, Greg_H), 74 guests, and 5 robots.
Topics128,169
Posts1,057,035
Members48,458
Junior Member
Junior Member
HEY DUDE'S IV'E DONE EVERY THING I COULD THINK OF TO GET MY GAS HAND TO WORK FIRST THING I FOUND WRONG WITH IT WAS THE COPER THINGEE THAT RUNS UP TO THE FLOAT LEVER WAS BROKE I FIXED IT BUT IT STILL DON'T WORK IT'S WAY BEHIND EMPTY I JUST PUT TEN GALLONS IN HER,WHAT ELSE COULD BE CAUSEING THIS PROBLEM. THANKS MARK [/LIST]PLEASE HELP
try replacing the gas tank sending unit. Chevy Duty has a decent unit that'll run you about 60 bucks with shipping. Comes with a new rubber gasket.
If, in fact your sending unit does still work, check all the ground wires. Although the price of replacing your sending unit may seem high in the short term. How much time may be spent working on the problem? What price can be put on piece of mind or reliabilty? A new sender will not leave you stranded on the side of the road out of gas. cool
If at first you don't succeed, get a bigger hammer.
1941 Pontiac business coupe
1947 Chev Coupe
1969 GTO ragtop
